how to use the IMAX B6AC multi charger?? HELP >
Old 03-16-2012, 04:00 PM
Default how to use the IMAX B6AC multi charger?? HELP
hey everyone.
just started useing this new charger..
anyone that has used it or has one..
when do i know that the charging process has commenced??
ive got 2x 3600 reedy nimh wolfpacks.. at 7.2Volts..
so ive put the timer to 110min instead of 90min.. since there an extra 300mah..
any useful info will be appreciated..
MasterComander is offline
Old 03-16-2012, 05:08 PM
nitroexpress's Avatar
Originally Posted by MasterComander
hey everyone.
Timer? What timer? If it has a timer, I never use it. Mine beeps when the charge is completed.
nitroexpress is offline
Old 03-16-2012, 05:10 PM
all figured out
well it has a timer.. where when it has reached the set 3600mah limit.. and at 100min..
it ll make sure it only charges upto that..
Old 03-16-2012, 07:04 PM
Sounds like you are charging at a fairly amp low rate? On the nimh setting they should go to the delta peak auto shutoff, the pack should get a little warm. If they aren't you should be able to raise the time limit and/or bump the amps up some. If they are getting too hot to hold may need to reduce the NIMH Sensitivity.
Dave H is offline
