nerdyrcdriver project sw
Yeah, it is fun to drive around with, but isnt practical. I need to find a way to wire in the foot pedals. I will probably end up getting an arduino mini and wiring that in. (after writing the code and testing with my normal arduino). Just a fun little side project that only cost me $4 (including foot pedals, not used yet). I had everything else lying around. It will be fun to use with vrc as well. But I have a problem with my pc right now that causes it to crash with vrc (I may have done a little bit to much spring cleaning on my hdd and wiped out a few windows files it relies on). More of a fun thing to make and play with. It will be interesting if anyone can manage to use it at the track. (probably after I wire in the foot pedals) it is SUPER easy to bump the throttle and send the car much faster than you intend it to go. I know it looks sideways (and it is) but that is an easy fix. I just need to get around to doing it. The wheel functions properly and everything, really it is just cosmetic that the wheel is turned sideways. But I will set it straight tomorrow or the next day.
Right now the wheel is wired to the fs-gt2 and that will probably remain the same to keep anything like an xbee from getting damaged on the car. But I might use an arduino in the wheel itself to wire in some foot pedals I have to go along with the steering wheel. So it is more like driving a car instead of turning a wheel and a nob to go forward or backwards. Plus it would offer more control over breaking and reverse. That is the plan anyway.
Actually, now that I think about it, are most pots analog or digital?
How about using the arduino the read the pedals and then this http://www.sparkfun.com/products/10613 connected to the TX .
If im going to use an arduino at all, I might as well just make it simple and use the pwm output on it to send the signal to the tx.
