New KO Propo Radio
#1906
Hello Chad, You are the man my friend. Really appreciate your help and more so your personal time used to provide help. RCTECH has a bunch of great members willing to go out of their way to help, thus your a prime example.
I guesse for a OCD person like myself the $40 is worth it. Don't know exactly why having two different languages on the display screen bothers me however as mentioned the OCD within me is the cause.
Thank you again. Looks like I can go with the EX-2 and add an extra $40 for the USB adapter and still save quit a bit of coin over the EX-RR.
Again much appreciated my friend. Looking forward to having a new radio thus I especially look forward to having the 3D throttle trigger again as it's one of the major reasons I loved my Euros EX10.
#1907
That's a good point. I am going to email KO America to find out or possibly the fella at Absolute Hobbyz may know.
#1908
I did some digging and this is what I found out!
Software v1.06 has the English only menu. More details can be found here: kopropo (dot com) /america/support/ics-interactive-communication-system
At the link above, you can also download the ICS software. I'm told that you will need the USB adapter, which is about $40 IF you need (or choose) to update the software on your radio: amainhobbies (dot com) /ko-propo-ics-usb-adapter-high-speed-kop61028/p252545
I also want to change language. Bought mine February this year from amain and came with both languages.
I wonder if I can use this cable and software to change it? Anyone knows?
Also, somebody selling this ICS cable around here?
#1909
I believe you can upgrade software to v1.06 but as Chad advised you would need ics USB adapter. He put the link to the adapter above.
#1910
Broke my trigger at the IIC this year on my EX-1 KIY (not sure of my version, but it was purchased in March 2014).
I'm trying order a new trigger, but they all say for Expert Grip. How do I know if I have an expert grip? I also see an Expert Group 2.
Trying to sort out what I need or should get. Triggers are ~$10 but say expert grip; the whole replacement is ~$125, and would rather not go that route unless required.
Recommendations? Thanks.
#1912
#1913
anyone using the ACCEL function on Ko radios?
#1914
Just wanted to share. I've used an M12s and a Lynx 4S in the past and just got to try the EX-RR. Imo this is the best driving TX that's on the market. I feel super connected to my car and it's super easy to get corners right. Just feels right.
#1915
I've had no glitches, signal dead spots or so on with either of the radios so far. That has been a serious problem on a couple of the tracks I race on with any Sanwa (Airtronics) or Spektrum radio. Most of my buddies have made the switch to Futaba, but that price is just too outrageous for a radio that isn't any better than an EX-2 with a fancier screen.
#1916
Hello. I have 2 questions and both are about drag brake. I have an EX II.
1. I use the ESC to get the drag brake close, and then I goo to the feel menu, and apply negative feel on the throttle to tune the drag brake. Is there a better way to do this?
2. In the Euro truck class, the ESC does not have a drag brake feature in brushed mode. Any suggestions on how to add some with the transmitter?
JOC
JOC
#1917
For neutral brake: on my EX-RR. 1)throttle, 2)offset,3) back arrow.
#1919
As far as I understand Neutral brake (brake at neutral) and drag brake is the same thing.
F.Y.I. here is a copy of EX-2 features from KO web site:
Throttle:
Trim, Travel F, Travel B, Sub Trim, Trim Rate, Turn Speed, Return Speed, Punch, Curve, Reverse, Neutral Brake, Brake Override, ABS, Accel, AutoStart, IdleUp, Feel
Throttle:
#1920
Throttle:
Throttle:
That was the hot ticket. Thanks.
JOC
