Team Orion Vortex Race Spec BL ESC
Trying to set up a new vehicle.
RT5 -Thunder power Lipo - Above ESC ORI 65006 - Ko Propo Servo - Thunder Power 17.5 BL Motor.
I do NOT have the PC interface.
Can I get it in to a "blinky" mode with out the PC interface?
Pat Voelker
Omaha Ne
Pat Voelker
Omaha Ne
Last edited by PVoelker; 01-03-2012 at 06:36 AM. Reason: fixed the cog with negitive timing
Thank you for the reply.
I wondered if the name of the ESC was literal.
So there is no timing in this ESC?
That is very cool, that means I can simply run it as is in 17.5.
I do have to turn down the motor timing to -10 degrees though or this thing cogs like nobody’s business.
motor
Yes I tried a trinity 2 and it also cogged at low RPM, that’s what made me think there was a bunch of timing or boost in the ESC. When I set negative timing in the motor cogging goes away and the thing is a rocket?
I am new to the ESC so it kind of has me stumped for now, you referred to mine as an R10 and that may be the newer version of what I have.
Pat V
R/C Tech Elite Member
ahhhh....I think you are referring to the older Orion esc that was a rebadged KO BMC?? I dont think Coach had R10's
if so....yes that esc has timing, not sure what profile is zero timing......if you go to KO's site, you can probably dl the manual.
this esc I bet is the one you are referring too, Nigel had some of those units
http://www.rccaraction.com/blog/2008...e-spec-bl-esc/
