Starter Box Lipo and Charger
I just bought an OFNA Truggy starter box and am considering lipo. I know that I need a 4s battery, and am looking at some of the hobbyking models. I'm not really looking to invest a ton in a charger since this will be the only lipo I'll be using. What is the simplest and most affordable way to charge this battery properly?
Thanks for your tips.
4S lipo needs more power than a cheap 50watt charger has to charge at 1C unless the lipo is only about 3000mah. Assuming you will wind up with a 4S in teh 5000mah range charging that at 1C requires 84watts from a charger. Using a 50watt charger would mean charges will take a long time - prob in the 1.5hr range vs the ordinary 1hr at 1C charge rates.
If charge time isn't an issue, look at the 50watt IMAX B6-AC Charger/Discharger 1-6 Cells (GENUINE) - HK also sells a fake or copy of this charger, but its less reliable - some are good some not so good....
If you want normal 1hr charge times, look at HKs 80watt Turnigy Smart 6 charger - it is a DC powered charger and wil need a power supply that can supply 100watts. Personally, I have had things turn out better when I buy more charger than I think I need and would look at the 200watt EC06-10 and a 220+watt power supply - but that's me, I usually wind up needing to charge more and bigger rather than actually sticking to plans.
Plan on getting a low voltage alarm to protect the box lipo from over discharging. I've seen a lot forget overdischarging and ruin bump start lipos this way. One of the $5 type lva off ebay will work.
