Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-28-2004, 05:02 PM   #46
ChrisP's Avatar
Send a message via Yahoo to ChrisP
And the fact that you can charge 4 cell packs at greater than 4.5A which is HUGe if you run stock 12th scale
ChrisP is offline   Reply With Quote
Old 12-28-2004, 05:10 PM   #47
dakrat's Avatar
really? i thought its 5A
dakrat is offline   Reply With Quote
Old 12-28-2004, 05:16 PM   #48
ChrisP's Avatar
I think the Triton caps out at 4.5 or something silly like that....
one of the locals tried it...got frustrated and dumped it a while back
Old 12-28-2004, 05:17 PM   #49
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
newracer: there on the way
Tre's
Custom Graphics - Race Plates/Wraps & Pit Products
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 12-28-2004, 05:20 PM   #50
ChrisP's Avatar
It should be a hot seller Tres....
so far the only real complaint I've heard from people about the charger is that it says 'Duratrax' on it
Old 12-28-2004, 05:25 PM   #51
Sign me up Tres my charger's in the mail.
BigNick is offline   Reply With Quote
Old 12-28-2004, 07:01 PM   #52
Bob Nilsen's Avatar
Just got mine today, initial thoughts:
Jog wheel is kinda cheap feeling... the "tactile feedback" isn't in sync with the "audible feedback"... meaning turning the wheel one notch doesn't always register as an event. Weak.
The charger is very configurable... there are several things that I've wanted to do on my 16x5v6 (such as optionally cycle charge-discharge or discharge-charge) that this charger will let you do.
I'm also really into trying out the "reserve time" feature that let's you know how long a charge *should* take... and let's you schedule the start of the charge with a timer so that it peaks before the next race. That's f*cking rad.
I've noticed that the thermometer seems to be a few degrees off from the thermometer on my multimeter... but i'm not sure which one is more correct. I anticipate the thermometer getting a lot of use... letting me more comfortably experiment with higher peak detection thresholds without having to watch the charger.
One thing that I'd love to see Duratrax (or whoever made it) add: A deep discharge mode. I typically discharge batteries at 8 amps, then let them rest for a minute, then 4 amps, then 2 amps.... the lower discharge rates seem to suck the last bits of energy out of the batteries better... resulting in them having to spend less time on the equalization tray.
Bob Nilsen is offline   Reply With Quote
Old 12-29-2004, 08:03 AM   #53
newracer's Avatar
Originally posted by dakrat
i cant beleive your selling ur tritons for ice. the only difference is the discharge rate. hahaha.
Actually there are a lot more differences. One thing I don't like about the Triton is with some packs it takes a while to "ramp" up to charge amps and even some it never gets up to the set amperage. Also my main complaint is that you set the peak detection ina totally different screen than the rest of the settings and it does not change when you change charge profiles. Also having another charger with a motor run will be nice. That way when my GFX is busy I can still cut comms.
newracer is offline   Reply With Quote
Old 12-29-2004, 08:04 AM   #54
newracer's Avatar
I heard, I emailed you about it a few days ago. Let me know when they are avaialble.
Old 12-30-2004, 05:33 AM   #55
Cole Trickle's Avatar
The bad thing about doing like this, is increased risk of cell reversing.
Tamiya DF-03 w. slipper clutch, 18x1.
Schumacher Mi2 - HPI Pro2. Both racing indoor carpet, stock class.
Cole Trickle is offline   Reply With Quote
Old 12-30-2004, 07:59 AM   #56
Ended up ordering the Ice....
From the explanations I'veheard the 3-phase charging may be a benefit for dead-shorted batteries, by usinga lower rate to wake them back up before blasting them with a high current charge.
Net pricing on the Ice just looked to attractive to pass up.....and if it doesn't work out, I'll simply buy another charger.
Nosram isn't an option as theyhave no presense that I know of in North America.
The nail in the coffin was the thread posted about the Pulsar 2 asking about the blue smoke. I have 2 friends that lost their Pulsar Comp 1's to static shock cooking the electronics. Until there is an explanation given, I'll stay away.
Who knows...6 months from now I may jump all over a Pulsar 2.
Burned LRP's is a heavy argument, cant beat that.
It's very interesting about the multi phase charging. It sounds logical to me. Please keep us updated.
Old 12-30-2004, 10:16 PM   #57
Registered User
Default ICE ROCKS
Hi i am from Perth in Australia and i have an ice and i think they are gret they have one major advantage over any of the major competitors in australia and the back up from the supplier over here in Australia is really good. LRP in australia is hard to get and expensive and the agent changes every 6 months so that sucks!!!
rob@phc is offline   Reply With Quote
Old 12-31-2004, 01:25 PM   #58
Send a message via AIM to rcguy2477
I just got an ice and its amazing compared to the pulsar and quasar. It has a ton of features, and for the most part they are very helpful. I also love the look of it, the blue anodizing looks great.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 12-31-2004, 01:29 PM   #59
Tres's Avatar
Ice everywhere except here...
Where's my UPS man...
Even the snow has melted! all 20" of it
Tre's
www.tnt-fx.com
Old 12-31-2004, 05:39 PM   #60
RCknight's Avatar
Default my only complaint...
is that built quality seem lacking. Then I fist opened it up and pulled the stickers off the sceen, the face plate came out. The dial seem cheapy, but it works.
RCknight is offline   Reply With Quote
Forum Jump
DuraTrax IntelliPeak ICE DC Competition Charger mikemaiers R/C Items: For Sale/Trade 5 12-06-2007 02:51 PM
For sale Duratrax ICE IntelliPeak Competition Charger mmhobbies R/C Items: For Sale/Trade 4 06-04-2007 06:17 PM
WANTED (DuraTrax IntelliPeak ICE DC Competition Charger) juhn X R/C Items: Wanted to Buy 0 09-21-2006 03:07 PM
NEW DuraTrax IntelliPeak ICE DC Competition Charger F/S GatesRacing R/C Items: For Sale/Trade 10 05-02-2006 08:23 AM
DuraTrax IntelliPeak ICE DC Competition Charger RandomFellow R/C Items: For Sale/Trade 2 11-02-2005 10:32 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
