Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-20-2011, 07:55 PM   #1
Default desolder esc tips
I have to desolder wires that came on a lrp sxx v2. The 12awg that it came with is too heavy for pan car so need a smaller gauge. The manual said to try not to hold heat to the esc for more than 5 sec at a time and i was wondering if there were any tips for easiest removal. I have a 40w iron with a big tip but didnt know if it was too hot. I have a smaller iron but not sure it will work well on all the factory solder on the esc
vash42 is offline   Reply With Quote
Old 11-20-2011, 08:21 PM   #2
You want that 40W to transfer heat quickly. Get some solder wick or braid or a desolder tool (basically a syringe to suck up the excess solder).
AreCee is offline   Reply With Quote
Old 11-21-2011, 08:29 PM   #3
I use something like alligator clip to "absorb" the heat before it reaches the ESC board
minilantern is offline   Reply With Quote
Old 11-25-2011, 02:50 PM   #4
Worked, thanks for advice. Used a solder vacum and came off easy
