Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-13-2011, 04:29 AM   #1
Default quatro charger problem HELP PLEASE
after spending hundreds of dollars on high end batteries from different manufactures, trying to find out why my 4x4 sct would always dump on the last lap in the mains. I found that my hitec quatro charger is not charging the battery all the way. no matter which port im using. the charger shows 4.2v per cell but when you check them with a meter they are only 4.14-4.17 per cell. does anyone know if i can adjust the voltage through some kind of programming or internally with a pot or something. the charger works fine besides this. HELP PLEASE. I'm tired of spending money.
Losi xxxsct 17.5
Losi xxxsct mod
Losi 8ight 2.0 tekno conversion
Ofna Hyper 10sc
pro306 is offline   Reply With Quote
Old 11-13-2011, 04:00 PM   #2
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
3-6 HUNDREDTHS of a volt isn't your issue with "dumping" on the last lap.
Adjusting the calibration of voltage in the charge isn't an option.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-13-2011, 04:37 PM   #3
Are you charging them with the balance plug connected ?
Can always try a lower charge rate, should force them to terminate later
Cheers
Slash Platinum
Xerun 150, Tenshock SC401 3500kv
Gensace 40c
crusey_aus is offline   Reply With Quote
Old 11-13-2011, 07:51 PM   #4
Cheers
yes im using the balance plug. the charger says they are 4.2 per cell. i checked with a meter then put it on my brothers charger and it confirmed the meters reading. his charger put and extra 220mah in the battery.
Losi xxxsct 17.5
Losi xxxsct mod
Ofna Hyper 10sc
Old 11-14-2011, 06:41 PM   #5
Trader Rating: 21 (100%+)
I'm not sure, but these type chargers seem to have a calibration menu of sorts. You hold the inc an dec buttons down and power up - it supposed to bring up a calibration menu - if it does, what you do after is guesswork. Try searching on RCGroups in the batteries and charger therr - I know the Quattro is discussed over there -0 see if you can find and calibration info.
Good luck
Duster_360 is offline   Reply With Quote
