Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-11-2011, 10:34 AM   #1
Zao18's Avatar
Default Disabling telemetry display on DX3S
I am not bothering to use the RPM sensor anymore, since the sticker lasts maybe an hour before it's coated in dirt and half torn off. Does anyone know if you can disable the telemetry displays on the transmitter, so I don't constantly have that "no telemetry" alert flashing at me?
Hotbodies D8T, Hitec 7955TG servos, "Clocked" Werks B5 w/ 2013 pipe, M2C 4-shoe clutch
Losi 810 buggy (converted Ten T), M2C Racing clutch, Hitec 7955TG servos, 125cc fuel tank
Spektrum DX3S w/ SR3300T receivers
Zao18 is offline   Reply With Quote
Old 11-11-2011, 01:17 PM   #2
In the main menu you can choose the action of the rolling selector
The options are ...........
Main
Telemetry
Toggle between
Set it at "Main" and you wont see the Telemetry
Cheers
Slash Platinum
Xerun 150, Tenshock SC401 3500kv
Gensace 40c
crusey_aus is offline   Reply With Quote
Old 11-11-2011, 07:00 PM   #3
Zao18's Avatar
But then that will hide the temp and voltage telemetry right? I want to be able to see the voltage and temp, but not the speed/RPM. My apologies, I should have specified that in the first post.
Old 11-11-2011, 07:36 PM   #4
No such option
If you are getting the "No telemetry connection" then the temp / voltage readings will not be accurate
The telemetry part of the signal has a very limited range
Cheers
Slash Platinum
Gensace 40c
Old 11-11-2011, 09:45 PM   #5
Zao18's Avatar
I am getting the no telemetry message because I have purposefully removed the speed/RPM sensor. My temp and voltage readings are just fine.
As for not being able to individually hide each readout, well that's a shame but I am not surprised. I think you can only do that with the DX3R.
