thunder ac6 question lipo to life
I'm not understanding my AC6. If I charg my is lipo then want to charge my reciever pack, life, how do you change it over or does it change it automaticly. I tried to save a lipo setting and a life setting and can only save one or the other.
In the menu where you setup the parameters for charging lipo, it'll ask for the voltage per cell, this is where you can select the voltage per cell for life instead of lipo. The charger groups the lithium batteries together under lipo and allows you to select the per cell voltage to change between them.
Thunder AC6 Charger | LiFe question
Just getting back into this hobby after being inactive for many years. Subsequently, I bought a ProTek LiFe for my Futaba 4PK surface radio. So all my RC batts are lipo/liFe at this point
Anyways, I followed the LiFe instructions that are posted on this page, however, my AC6 charger/balancer read each cell at 3.60 volts per cell. So, I guess the battery ships fully charged at 7.2 volts, but with a 6.6 volt sticker on it I'm spliting hairs, I guess, but shouldn't it be 3.3 per cell, instead of 3.6? Vendor says the batt ships at 50% capacity, not 100%?Maybe this batt was returned? Regardless it's in my 4PK. Display seems nice and bright... maybe even brighter than the lame stock batt it came with LOL
