Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-08-2011, 08:49 AM   #1
Default Can all sensored brushless motors be advanced?
I was wondering if all sensored brushless motors can have their mechanical timing advanced. I have a 13.5 LRP X11. It does not have any markings on the can for timing locations, and it does not have seperate screw holes on top for different cap mounting locations. The 13.5 class I run in allows timing advance and I wanted to know if I could make this motor work. Thanks!
camdog04 is offline   Reply With Quote
Old 11-08-2011, 11:31 AM   #2
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Nearly all motors have some form of mechanical timing advance. You should be able to adjust your LRP X11 by following the directions here.
MarkA is offline   Reply With Quote
Old 11-08-2011, 01:58 PM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
You sure it's an X11 and not an X12? If it's an X12, you remove the plastic cap and there are different inserts you can use for different timing.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-08-2011, 02:16 PM   #4
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
The only ones i know of without timing advance on the motor is the new hobbywing spec sensored motors in their "Justock" combos and a few other off brand motors..
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 11-09-2011, 09:53 AM   #5
Buckaroo's Avatar
I have the same motor. It is a very early version X11, and timing CANNOT be advanced on it. Later run X11s you could turn the timing ring, and they have marks.
Overall it's still a good motor, pulls nice and strong! Heck, you can still get rotors, bearings, and endbell parts for 'em!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-10-2011, 09:03 AM   #6
Default Thanks
Thanks everyone! I will try it out!!
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Speed Passion 1/8 scale brushless Applesauce Electric Off-Road 1000 02-28-2013 08:09 AM
