Need some help - Lipo/Charger question/issue
The individual cell and overall pack voltage are not the same, is it a lipo issue or a charger issue? As an example, on a 2s lipo, I will get a reading of 3.95v per cell, but overall pack voltage will read 8.01v. I have noticed that the overall pack voltage will start to drop when nearing capacity (full charge), even though the individual cell voltage will stay the same.
Also, what would be the more accurate reading, should I go by overall pack voltage to stop charging or individual cell voltage? Thanks in advance for any help/assistance!
I will try and answer your questions but if you don't mind me saying so, I think you should to read up on your batteries.
Here's a good place to start:
http://www.rchelicopterfun.com/rc-lipo-batteries.html
In the mean time, I will answer your question. The discrepancy you are seeing between cell and battery (pack) voltage is normal. Every lipo cell in the world has a nominal voltage of 3.7V (Depending on charge it will range from <3.0V to 4.2V). The 2S in a 2S battery means that the cells are connected with 2 cells in SERIES (3S would be 3 cells in series etc, etc...), this means their votages are added together.
Read more on Series and Parallel connections here
http://batteryuniversity.com/learn/a...configurations
Now if you looked at your individual cell voltages and found that 1 was at 3.4V and the other was at 3.9V, that would be a issue. That means you need to balance your packs.
This brings me to the issue of Charging, do you have a LiPo charger? If not please get one, they charge in a very different manner than NiMH's and NiCads. The simple solution is to find a reliable LiPo Balance Charger that will balance your individual cells while it charges your LiPos. The dangers of improperly charging LiPo's are well documented.
Star
Star
Star
Star
I have an icharger 208b. It would have been nice if you had read the post a little more carefully, because as far as I am aware of, there would be no way for me to get an individual cell reading from a non lipo charger. Sorry if I sound a little short, just tired of people responding without an answer to questions, and sounding condescending.
The pack voltage reading comes off the main charge wires, due to the charge current going from the charger to the pack there is some voltage difference, the charger is at a slightly higher voltage than the pack.
For the balancer the current flow is in the opposite direction, current if any is flowing from the pack towards the charger. Thus the charger balance circuits may read slightly lower than the actual cells, or at least no higher if no balancing is going on.
As the charge current comes down during the Constant Voltage part of the charge, the voltages will converge.
The balancer readings should be more accurate, especially on a well balanced pack.
That is not unusual, you probably are OK. (Although too large of a difference suggests it's possible the charge leads and connectors are higher resistance and/or longer than ideal, which will tend to increase charging time somewhat.)
Thanks again for the help and explanation!
Yeah, I know that and you didnt really answer my question. Since EACH cell is at 3.95, in a 2s lipo, total pack voltage should be at 7.9, but what I am seeing is 8.10 - 8.25, which obviously doesnt add up. If each cell is at 4.20 on a full charge, total pack voltage should be at 8.40, but I will typically see the charger showing 8.46-8.50.
As it nears the end of charge, and ultimately finishes, the voltage does come down in line with the individual cells. All is good, had a Triton eq charger, 5A max 50w charger, was good , but needed better lol. Then had a Dynamite Passport Ultra, 8A max 100w charger, but balancing seemed to take forever if the cells were off by a little. Now I have the icharger 208b, 20A max 350w charger and so far, very happy with it. Nice to have data logging capability too.
I did however check the cell voltages with a few different multimeters, everything seems good. Nice to know I have the option of recalibrating if needed though
Badaml
First off I am glad you got the answer to your questions.
I was not trying to condescend, just trying to help. I must admit I use my multimeter to get all my readings from battery voltage to individual cell voltage so I had no idea that by providing an individual cell reading it proved you had such a charger Either way I misunderstood the question as asked and I apologize.
I'll leave it that because I can understand your frustration considering the true nature of your question.
Star
Star
Badaml
Star
Star
Just saying, it's a fairly straightforward concept, as much as you post on the subject somewhat surprised you haven't encountered or noticed this before.
