Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-13-2009, 02:24 PM   #871
I thought you had to use digital servos with HRS???????
nutz4rcyktw is offline   Reply With Quote
Old 02-13-2009, 02:25 PM   #872
getpip's Avatar
Originally Posted by Nitorious View Post
Hi,I seem to be having alil problem with either my R303fhs or my module on my 3pks. Everytime i try to change the channel on both things it seems not to work. Example: i have my reciever and module on channel 71 and I try to change the channel while the radio and reciever are off, so i change on both to channel 74, turn on both thing and nothing. Check another channel and nothing. Go back to channel 71 and it works. I dont understand why it does that.
Another problem im having is both my futaba servos (throttle & steering) which are standard 3003, they seem to keep humming and they both get hot. The radio is in Hrs mode and if i try to change to PPm mode turn off the radio and turn it back on, nothig works. Put it back to Hrs mode and it works but the servo hums.
My Servos and R303 reciever is being used on my 720 with of course my 3pks and i have a feeling that my reciever is bad but i dont want to assume. If you guys could help with my lil scenario her it would be much appreciated.
HRS mode will only work properly with digital servos.... This could be your problem as the 3003 is an analogue unit. HRS mode will cause the servos to overheat because of the way the voltage is delivered.
Reset the TX to PPM mode (FM) and try again.
TMG4RS09/Mega DS2
Futaba 3pk/Spektrum
Thanks to: CometRC.com
getpip is offline   Reply With Quote
Old 02-13-2009, 02:34 PM   #873
Nitorious's Avatar
I tried changing to PPm mode and the servo's dont work. Before that I had 2 airtronics 94362 servos and it did the same thing in Hrs mode. I switched it to PPM mode and the same thing. So with either the digital or standard servo they tend to hum and i can't change the channel either. It stuck on one channel.
Thanks for the help.
NiToRiOuS1
Nitorious is offline   Reply With Quote
Old 02-13-2009, 02:54 PM   #874
Were you able to change channels in the past? Has anything else been changed when this started happening? Is your battery strenght OK? Tried cleaning the receiver?
I hate to say this; but you should disconnect everything, and go back to basics. Start with each componet and see what does and doesn't work. Will motor work with servos disconnected, will servos work with motor disconnected, if you have personal transponder same as previous, check everything you can.
Not trying to be a smart a** but if you didn't know that HRS needs digital servos, how familiar are you with this radio?
Old 02-13-2009, 03:43 PM   #875
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Make sure you cycle the power when switching modes. Just a thought.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-13-2009, 05:04 PM   #876
Good point, if you don't turn it off and on again; it may not reset the values. I had forgotten about that.
Old 04-30-2009, 02:30 PM   #877
I have a 3PKS and looking to go 2.4 what is the difference between futabas fasst system and a spektrum system for the 3PKS?
Nothing Beats the Kit Setup
jjdoyle is offline   Reply With Quote
Old 04-30-2009, 03:15 PM   #878
ezveedub's Avatar
Each system will only work with their brand Rx. You won't be able to used a Futaba FASST TX with a Spektrum Rx and vice versa. Also, the Futaba unit will utilize the HRS system, while the Spektrum cannot (slower response).
Old 04-30-2009, 03:42 PM   #879
Trader Rating: 18 (100%+)
I just got the ASSAN 2.4g X8 version 2. if the weather is good I'll get to try it out and compare it to my 3PM FASST.
with EMS shipping it took 5 business days from HK to Illinois. I'll do some comparison testing.like range and stuff.
i'll be at a bash party, with about 10-15 cars running at the same time. should give a pretty good idea of how well the system runs. 90% of the guys seem to be running either futaba or spektrum 2.4g
devilchrist is offline   Reply With Quote
Old 05-03-2009, 07:19 PM   #880
can you mix analog and digital servos on the fasst system
tom slick 50 is offline   Reply With Quote
Old 05-04-2009, 01:36 AM   #881
Yup, just don't run it in HRS-mode or you'll fry the analog servo.
adam lancia is offline   Reply With Quote
Old 05-04-2009, 02:14 AM   #882
Toh WL's Avatar
Spektrum also got SPM1015 DSM System for Futaba HRS. That was designed for 3PK.
I was thinking if anyone tried using Spektrum HRS with Futaba made HRS Tx, Rx module or vice-versa.
Does it worked?
Toh WL is offline   Reply With Quote
Old 05-05-2009, 03:37 AM   #883
NZDriver's Avatar
FAAST technically has a faster response than the Spectrum Pro module, but if you can experience the difference you are better than most drivers on the plannet !
Be careful - while it might be the "cool thing to have" some FAAST systems have been suffering from thermal shutdown problems in some 1/8th gas buggies - i know the Xray 808 had problems, just check out Xray's forum site and search for FAAST to see what i mean. A mate running a 808 switched from FAAST to Spectrum and fixed his problems, he wasnt able to run 20mins without going into shutdown.
BUT, if you arent running gas offroad this shouldnt be a problem.
Hong Nor X2CR/OS
Xray T2'008/LRP
NZDriver is offline   Reply With Quote
Old 05-05-2009, 05:24 AM   #884
ezveedub's Avatar
The FASST system always has issues with the 808. The Rx box is so close to the engine, the heat makes it shutdown. If using a 808, then use the HRS FM system.
Old 05-05-2009, 09:10 AM   #885
so wahts the best mode to run with mixed analog and digital
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
blackdiamond
Forum Jump
Futaba 3PKS synthisizer users please assist me Drunkendori Electric On-Road 14 07-14-2007 10:25 PM
Calling all RB V.12 5 port users nitrobeast Nitro On-Road 1 12-07-2006 03:53 PM
Futaba 3PJ/3PJS/3PK Users: 2 Quick questions. Artificial-I Nitro On-Road 0 02-02-2006 09:41 PM
Calling Out Rto!!! charlie_b Racing Forum 3 08-12-2003 10:21 AM
Calling all MT-Mad ppl! pineapplet Singapore R/C Racers 0 01-31-2002 04:40 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
