Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-14-2005, 11:06 AM   #151
rc-zombies's Avatar
Originally posted by JayBee
Where can I find that steering wheel?
- jb
Integy sell some and also try Ebay...
Old 01-14-2005, 11:07 AM   #152
Clegg's Avatar
Originally posted by rc-zombies
Mclaren/Mercedes
McLaren will be good this year I think. Williams are down atleast for another year, BAR should be very powerful I think Sato and Button are quite fast.
-Joe
For Racing: BMI DB12RR-LiPo, For Fun: HPI Blitz
RCP 1/12th Scale 2009/2010 spec - Updated Often: http://www.rctech.net/forum/5734711-post1754.html
R/C Racing is: 10% skill, 10% equipment, 20% luck, 50% bullshit and drama.
Clegg is offline   Reply With Quote
Old 01-14-2005, 12:15 PM   #153
JayBee's Avatar
Trader Rating: 23 (100%+)
Post
Thanx zombies...
- JB
JayBee is offline   Reply With Quote
Old 01-14-2005, 03:47 PM   #154
Default Re: Re: Re: 3pk transmitter case/bag
Originally posted by billwilner
How much was shipping from Hong Kong to US?
Bill
$25 with the radio as well I believe
Galifrey is offline   Reply With Quote
Old 01-14-2005, 03:59 PM   #155
Default 3PK synth module: what receiver to use?
The info on Tower's page about the new "black" 3PK #FUTJ2901 including the #PK-FSM75 synth module shown at
http://www2.towerhobbies.com/cgi-bin...I=FUTJ2901&P=K
was apparently recycled from the existing text about the old "platinum" 3PK #LXCML6** at
http://www2.towerhobbies.com/cgi-bin...I=LXCML6**&P=M
My guess is that the text about the #FUTJ2901 must be incorrect where it implies that the synth module is compatible with the
R203HF Receiver HRS 75MHz, #FUTL0344
The #FUTL0344 receiver is crystal-based, not a synth unit, so it can't be compatible with the #PK-FSM75 synth module.
What synth receiver does Futaba intend be used with the #PK-FSM75 synth module?
I have emailed Futaba several times and had no response.
Anyone know?
Bill Wilner
billwilner is offline   Reply With Quote
Old 01-14-2005, 04:38 PM   #156
KiwiKid's Avatar
I got mine from Rainbowten.
- jb
KiwiKid is offline   Reply With Quote
Old 01-17-2005, 09:35 AM   #157
lee82gx's Avatar
Ive worked with paint strippers... it will definately mess up the plastic...
You're better off sanding it down lightly... Prime it...
and spray with Laquer paint.. more durable than Enamel.
of course..you'll have to take the TX apart first.
can i get a step by step on how to take it apart?
I want to paint my 3PK yellow or black...
lee82gx is offline   Reply With Quote
Old 01-17-2005, 09:42 AM   #158
Default Surprising answer from Tower Re: 3PK synth module: what receiver to use?
Me to Tower:
The info on your page about the new "black" 3PK #FUTJ2901 including the #PK-FSM75 synth module was apparently recycled from the existing text about the old "platinum" 3PK #LXCML675. My guess is that the text about the #FUTJ2901 must be incorrect where it implies that the synth module is compatible with the R203HF Receiver HRS 75MHz, #FUTL0344. The #FUTL0344 receiver is crystal-based, not a synth unit, so it can't be compatible with the #PK-FSM75 synth module. What synth receiver does Futaba intend be used with the #PK-FSM75 synth module?
Tower:
The synthesized module is compatible with the R203HF receiver. Our information is correct, the radio has a module that does not use crystals, but when you switch channels the receiver crystal needs to be changed.
Me:
That doesn't make sense at all. The whole point of going synth is so that you don't have to change crystals at all. I'd contact Futaba to confirm that.
Tower:
We have confirmed this with Futaba, the receiver in that combination still uses crystals. If you would like to check, look at Futaba's lineup, there is no fully synthesized receiver right now for car use.
Old 01-17-2005, 09:46 AM   #159
Originally posted by KiwiKid
I'm a self confessed RC addict! My collection includes: TL-01 (4), TA-03FS, TA-03RS TRF, TA-03R (2), TA-03F(1), TA-04R, TA-04 TRF, 414m2 (2), 414m WCE, 415 TRF, TB-01, TB-02 (2), TB-EVO-III, TB-EVO (Surikarn Ed), TB-EVO IV, F103, F201 (3), M-03, Tamiya Stadium Blaster, MR4TC-SP, B4 Stealth, Kyosho RC NSR 500, TXT-1, Max Climber, TT-01
Do you own stock in Tamiya?!
Old 01-17-2005, 09:50 AM   #160
tomdav's Avatar
Default synth module
If I was you I would wait until the new Spektrum modules are out until making a major purchase. Crystals and freq pins will be obsolete. If you do buy the new synth futaba trans. you could use a novak synth. reciever. Why futaba would release the module and not the reciever to match is strange.
Tom
Camas WA
www.davesrctracks.net
tomdav is offline   Reply With Quote
Old 01-17-2005, 09:50 AM   #161
Clegg's Avatar
Default Re: Surprising answer from Tower Re: 3PK synth module: what receiver to use?
Me to Tower:
Tower:
Me:
Tower:
Yes thats right. You dont need Synth on both sides. I know plenty of people who use the Synth recievers with crystal based transmitters and vice versa.
-Joe
Old 01-17-2005, 10:30 AM   #162
dr_hfuhuhurr's Avatar
Trader Rating: 44 (100%+)
Had a problem Sunday with my 3pk in the main. The wheel kept going at full lock then there was no spring centering of the wheel. It did it once in the 3rd qualifier and then in the main. The first time it snapped back eventually and was OK. Haven't torn into it but has anyone else had this problem and how did you solve it?
Really sucks because it cost me winning the race I think
Thanks,
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-17-2005, 02:31 PM   #163
Thanks,
Blake
Glue the tyre on the rim of the steering wheel...
Its slipping off and making the wheel stick..
Old 01-17-2005, 05:12 PM   #164
Default 3pk bag
selling 3pk bag for 20.00 new
mrfastrc51 is offline   Reply With Quote
Old 01-17-2005, 06:20 PM   #165
Default 3PK synth module/non-synth receiver
Really?
But say you turn the screw on the synth module to, say, ch. 68 but the receiver has a crystal inserted for, say, ch. 84.
How will the two connect?
Bill
Forum Jump
Futaba 3PKS synthisizer users please assist me Drunkendori Electric On-Road 14 07-14-2007 10:25 PM
Calling all RB V.12 5 port users nitrobeast Nitro On-Road 1 12-07-2006 03:53 PM
Futaba 3PJ/3PJS/3PK Users: 2 Quick questions. Artificial-I Nitro On-Road 0 02-02-2006 09:41 PM
Calling Out Rto!!! charlie_b Racing Forum 3 08-12-2003 10:21 AM
Calling all MT-Mad ppl! pineapplet Singapore R/C Racers 0 01-31-2002 04:40 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
