hobbywing STOCK turbo ? for drift? how to set to maximun BRAKE ..
i am using on my drift CS kit..
is that possible i can fullbrake ? like handbrake effect. i know my orca can done this,, but i feel that my hw extreme turbo not enoug brake.. even i change to 100% brake force.. is there any other thing that i needed to do ?
sorry i pretty bad in explanations hope u know what i mean
You can try increasing reverse power to full 100%, even if you have reverse disabled this can help on some controllers. Beyond that there is not much you can do. I have the same ESC but always had more than enough brakes. YOu can also try different software to see if it improves.
It will never completely lock up the motor with brakes, but it should stop the car quickly and lock up the wheels unless you have very good traction.
