venom lipo battery 7.4 40c hardcase problem broken :(
yesterday i was practicing with my jammin scrt10 then my car stopped . it was the battery, i tried to charge it but the charger showed me connection break. so i decide to open my hardcase battery and this is what i found.
one of the battery terminals is broke. how this could happen? the battery is 2s but why it looks that it has four cells? any help please
I don't know if the broken terminal could be safely repaired. It would certainly take a skilled solderer. As for the pack, it is a 2s1p. Even though you see four cells two of them are connected in parallel so it doubles the mah output but the voltage remains that of a 2 cell pack.
repair
thanks for ur replies both of you.
im taking my batt. to the hobby shop. they have a skilled solder there!!! hope it works again
Paul from Venom here.
If you have your receipt, or can get a new copy of your receipt from where you purchased it from, we have our 1 year warranty that would replace this pack for free. If it is greater than 1 year, you would receive a discounted pack.
I sent you a PM with my contact info so we can arrange a replacement.
Paul Susbauer
Product Portfolio Manager
Venom Group International
Paul Susbauer
Paul Susbauer
Paul Susbauer
Still, the pack is clearly labelled as a 2S1P configuration pack. How did a 2S2P pack end up in there? To me, that's a bigger problem then a broken terminal.
Paul Susbauer
Paul Susbauer
I agree it's a 2s2p each cell is 3.7volts at 2500mah and a 40c discharge rate It is wired in series and parallel making it 7.4v @ 5000mah with a max discharge rate at 240 amps.
