HK-310 3 Channel 2.4ghz FHSS Ground Radio
Anyone have any knowledge about the HK-310 ?
Is it an offshoot form another popular Chinese radio such as a Flysky ?
http://www.hobbyking.com/hobbyking/s...4-286FBC96A5CC
Its better then the other one GT3-B, it has a range of 600feet+ .
Been using it for 4 months now no issues.
HK-310
Have been using on my RC8 for couple of months, pretty happy with features and reliability.
About to try out on Duratrax Evader EXT with Hobbywing stock brushless system to see how features work on electric setup.
Only odd thing to note is wheel only has small turning range compared to others, but doesn't take much to get used to it.
HK-310:
Features:
16 Model Memory with user programable names
2.4ghz FHSS Technology
Dual Rate
EPA
ST Curve
TH Curve
TH Hold
ABS (Anti-Lock brake)
Timer
ATS (Automatic Start)
BK Mix (Brake Mixing)
Custom Mix
Fail Safe
Neutral Calibration
HKR3000 3ch RX (Included)
Detailed User manual
HK-GT3b:
Specs:
Channels: 3
RF Type: 2.4Ghz AFHDS
Bandwidth: 500Hz
RF power: less than 20DB
Sensitivity: 1024
Low Voltage Warning: Yes (less than 9V)
Fail Safe: Yes
DSC Port: Yes (3.5mm PPM)
Charging Port: Yes
Power: 12V DC (1.5AA x 8)
Weight: 328g
CE & FCC certified
3.9" Blue Back-lit LCD
Programing Options:
Model Memory (10 Models)
Servos NOR/REV
Steering Trim
Throttle Trim
Dual Rate
End Point Adjustment
ABS Settings
EXP Settings
if you need a radio fast and the gt3b is out of stock its ok. the gt3b has a large thread here if you need any help with anything about it too. i can't see my car and still have range with the gt3b.
Features:
Dual Rate
EPA
ST Curve
TH Curve
TH Hold
Timer
Custom Mix
Fail Safe
Neutral Calibration
HK-GT3b:
Specs:
Channels: 3
Bandwidth: 500Hz
Sensitivity: 1024
Fail Safe: Yes
Charging Port: Yes
Weight: 328g
CE & FCC certified
Programing Options:
Servos NOR/REV
Steering Trim
Throttle Trim
Dual Rate
ABS Settings
EXP Settings
Hi Guys, sorry to bump an old thread. I just got this radio today and i'm having a problem. I'm using a Tamiya TT01D Type E. All stock,except an upgraded servo. If i use the stock radio, i can brake and reverse,but whenever i use this radio, i can brake, but cannot reverse. Any advice? Thanks in advance
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
So how do i on it?
I think should be alright. But i'm still wondering why i cant reverse my car with this TX/RX.
Anyone?
