novak ballistic 550 motor problem
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I have a Novak Ballistic 550 and i am having problems with it in to 2 spots on the rotor the motor will not turn when it hit the 2 specfic spots. I marked the pinion and everytime it hits that spot the motor doesnt turn. and this happened to 2 brand new motors. And the ESC is also new it is a novak havoc sc.
no one have any problems like this with their motors???
Super Moderator
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Trader Rating: 31 (100%+)
What do you mean by it won't turn? It doesn't run when powering it with the esc? Or is it simply hard to rotate by hand and "snaps" over; which is normal with a BL motor?
i marked the pinion in 2 spots and when the motor stops on either of the 2 spots when you press the throttle the motor will not go it happened to a 6.5 motor and a 5.5 motor!!!
yes its in the car no it happens when i stop the truck or i press the brake and the motor stops in the 2 specific spots and when it stops in the spots i press full throttle and it wont go.
