Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-21-2011, 11:31 PM   #1
Grand National's Avatar
Trader Rating: 24 (100%+)
Default Hyperion Duo 3 with 30 amp 360 watt power supply?
I was recently at the track and my charger was getting input voltage errors. This is the first time this has happened on my charger, I've been charging packs 2 at a time at the very same spot for months now. I just got fresh new 5300 mAh 65c Thunderpower LiPo's and it started getting input voltages. I hooked it up to a friends charger, and it charged it fine, no errors whatsoever. When I went home, I plugged the charger up to store the LiPo's, 2 at a time, no errors at all. Now, my question is, at the track, I use a power strip (multiple plugs on one outlet). Could this be negatively affecting the power supply and giving my charger errors? When I put the LiPo's on the charger at my house to store them, it worked fine, and I plugged it directly into the wall, no power strip. Could I please get your thoughts on this? Thank you very much!
Brady Grubb
FT B44.05 - FT SC10 - SC10 4x4
The Track, Gaithersburg, Maryland
Hobbypartz.com - Director of Sponsored Drivers
'01 Dodge Cummins 2500 built trans, 35" tires, Superchip, 5 inch exhaust
Grand National is offline   Reply With Quote
Old 04-22-2011, 07:05 AM   #2
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
What was the capacity of your old packs, was it less than 5300mAh? What amperage are you trying to charge them at? What other things are being run off the power strip at the same time?
Also, you may want to check this out before checking this out.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 04-22-2011, 09:02 AM   #3
If you are getting input voltage errors at the track but things are working fine at home then I'd say the track wiring is overloaded. Happens at every RC track (especially outdoor ones) that I have been at. To many people pulling off one circuit which means your power supply is not getting enough AC voltage in order to keep the DC voltage at a normal level.
kcobra is offline   Reply With Quote
Old 04-22-2011, 06:13 PM   #4
Trader Rating: 21 (100%+)
Next time you go, and have voltage errors, use your DVM/MM and check the voltage and see what's going on.
Overloaded circuit is what it sounds like...
Duster_360 is offline   Reply With Quote
Old 04-22-2011, 11:53 PM   #5
Thank you guys.
I've actually charged two 8000 mAh batteries at once at the track, but when my charger was getting input voltage errors someone was pitting across from me who was using a bunch of electronics. It makes perfect sense now that I look at it.
Brady Grubb
