Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-12-2011, 01:02 PM   #16
Trader Rating: 21 (100%+)
Uh, no, that would be in series and you want parallel. You'd still be charging an effective 2S lipo, but the capacity would be twice as large (in parallel voltage stays same, capacity adds, in series, voltage adds, capacity stays same).
The only way (besides multiple chargers or multi-port chargers) to shorten charging time is to increase charge rate. Charging at 2C will be faster than 1C, charging at 3C will be even faster and so on. Your lipos have to be rated for higher C charging and your charging equip has to have theneeded max charge rate and required watts.
I charge in parallel - right now since I'm using a 8S setup made from 2 4S lipos, I'm charging 2 4S 5000mah lipos in parallel at 30amps which is a 3C charge. Charge usually takes about 20min.
Duster_360 is offline   Reply With Quote
Old 04-12-2011, 10:38 PM   #17
kamahaobuilt13's Avatar
Trader Rating: 17 (100%+)
well i got a 5000mah 40c 2s but i heard that due to 5000mah i only can charge at 5amps im new to lipos sorry
Back in the mix
kamahaobuilt13 is offline   Reply With Quote
Old 04-12-2011, 10:55 PM   #18
ntrain42's Avatar
Trader Rating: 33 (100%+)
As another recommended. Grab an iCharger either the 206 or 306 models. Both will balance parallel charge 3 high mah 2s packs is 20-25 minutes without breakin a sweat.
ntrain42 is offline   Reply With Quote
Old 04-25-2011, 02:25 PM   #19
Dumb question, but how would one go about charging multiple packs at once with one of the iChargers? Would I need any additional supplies other than what's included?
Excellent Lipo Guide: https://rogershobbycenter.com/lipoguide/
Jason B is offline   Reply With Quote
Old 04-25-2011, 05:43 PM   #20
Assuming you have enough charger output power and max charge rate in your iCharger, this is what I use, Paraboard -
http://epbuddy.com/index.php?main_pa...uu595qfrmojqs5
The Paraboard plugs into the charger and the lipos you want to parallel charge plug into the Paraboard - both power wires and the balance connections.
Note that for parallel charging, the lipos have to be the same cell count, C rating and have a similar cycle history. They should be close in voltage before you plug them in as well.
Figure out what you need - example - I charge two 4S 5000mah lipos at 3C - that takes 30amps and needs 504watts, I use the 3010b iCharger. The paralleled batts are effectively a 10,000mah 4S lipo.
The best lipo charger? Cocopah Radio and Electronics 16 09-28-2010 10:03 AM
Help me buy a good LiPo Charger markhat250 Electric Off-Road 32 08-29-2008 09:51 AM
LiPo charger advice: Hyperion ac/dc vs. Orion avionics advantage jubilee Northwest Racers 19 03-11-2008 04:04 PM
FMA CellPro 10s LIPO Charger or8ital Electric On-Road 8 02-24-2008 06:21 AM
Best Lipo Charger and Why t4usee Electric Off-Road 39 02-07-2008 10:11 PM
