need help my traxxas 2.4 radio stearing does not work
If you've been playing with the menu settings, make sure the multi knob isn't set to steering percentage, and is turned all the way to the left. If it is on steering%, crank the knob to the right and you'll get your steering back. I made that mistake today actually took me a few mins to realize what I did. If you set it on the steering%, turn it down, and then changed what function the knob does, it will still stay at whatever % you left it at. I found it very confusing, and I think because of this and some other issues I've had with steering settings constantly changing themselves between packs, I'll be getting rid of the Trx system.
If it's not that, I'd check the servo plug at the rx. If it looks good, try the second ch1 spot. I've had one die on one of my rx's before, but the second ch1 works
