whats wrong with my brand new 9100t jr servo? please help
I just recently purchased a 9100t servo....and installed into brand new vorza from hpi...straight out of the box..and also replace the receiver from spektrum...dx3 in the process...after first run or two..I noticed...thatwhen turned to the left it does a hesitant jerk and sort of gives a throttle like if I tapped the throttle.......for a half a second...while doing circles to right in a slow speed it does circles smooth ...but when doing circles to the left ...it gives hesitant jerk of throttle power in the process of the circle...do I do something wrong? But I did connect the futaba connection right with the light color towards the inside...so Im puzzled ...can u inform me on what's going wrong?
Have you turned down the servo travel (end point adjustment) ?
Servo may be drawing too much current and cuasing issues with your ESC's internal bec
You may need to use a glitch buster style cap or external bec
If you have an old RX battery pack you can use it to diagnose the problem
Cheers
Cheers
