Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 06-23-2013, 08:12 PM   #106
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Have any of you had issues with your motors cogging at low throttle inputs? I have changed the sensor wire and ESCs, but the issue persists.
IIGQ4U is offline   Reply With Quote
Old 06-23-2013, 10:41 PM   #107
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Thanks for the breakdown. So what makes the versions different from each other? Is it faster than D3.5 Magzilla?
Originally Posted by hanulec View Post
Hi all -- not to rain on CT's parade, but the "v2" version of these motors are NOT ROAR legal. You'll want to look for the "v1" versions instead. I've been recently stocking them via the US importer, Prime Hobby Distribution. US Hobby stores and online dealers should be going through them.
here is the list of global distributors -- http://www.team-powers.com/index.php?thispage=partners
the part numbers legal for ROAR spec racing are -- http://www.roarracing.com/approvals/...lessmotors.php
Team Powers BLM-215100-PL Plutonium 21.5T
Team Powers BLM-175100-PL Plutonium 17.5T
Team Powers BLM-135100-PL Plutonium 13.5T
Team Powers BLR-TP125G 12.5mm Spec option Tuning Rotor
modified motors --
TP-BLM-XX100-PL (XX denotes wind:ex-35100=3.5T) Team Powers Plutonium
Racing4Evo is offline   Reply With Quote
Old 06-24-2013, 04:42 AM   #108
hanulec's Avatar
Trader Rating: 23 (100%+)
I know your can tell the different motors by their end bells. I'm not 1000% sure if the internals are the same. You can see the 3x 3mm screws are covered by the timing plate in the V1 version.
V1 motor -
V2 motor -
The question of "is it faster than an illegal motor"? I'll leave that one up to you to determine. I can say it is one of the faster legal motors available.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-24-2013, 04:45 AM   #109
hanulec's Avatar
i haven't seen this.
Art (Advil)- have you?
Old 06-24-2013, 07:46 AM   #110
Trader Rating: 19 (100%+)
No issues here. I have ran lower drive frequencies with the motor and have not found any cogging effect.
Perhaps the sensor board has failed.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 06-24-2013, 07:48 AM   #111
IIGQ4U's Avatar
I've used two sensor boards and rotors.
Do you think ESC punch control could have something to do with it? This is just odd to me.
Old 06-24-2013, 08:21 AM   #112
What ESC?
If you know someone with the Team Powers Motor unit they can check to see if the motor is active on all phases of the sensor board while installed. If not and the ESC supports it - increase the drive frequency of the ESC. You could try decreasing the punch control but in my experience punch had less of an effect on causing a cog.
TEAMORCA.SHOP
Old 06-24-2013, 08:54 AM   #113
IIGQ4U's Avatar
I used the Hobbywing V3.1 and the Speed Passion Reventon Pro.
Old 06-24-2013, 09:05 AM   #114
Does it cog with both of those?
TEAMORCA.SHOP
Old 06-24-2013, 09:12 AM   #115
IIGQ4U's Avatar
Yes, both ESCs. I'll try a few more things to try to get it figured out.
Old 06-24-2013, 09:40 AM   #116
IIGQ4U's Avatar
Nothing is happening when I rotate the timing ring.
Pretty much told me it was the sensor wire. All is well now.
Old 06-24-2013, 09:41 AM   #117
Trader Rating: 17 (100%+)
No. I haven't seen this. My experience is with the Tekin and the Team Powers speedos. Currently I am using our 140A version 1.2 speedo and it has not shown a sign of cogging. I also have the timing cranked!
I was told one of the rule changes was that the motor stack had to be exposed when the motor is dissassembled. The current V2 design did not take that change into consideration. It was designed before the new rule changes and will not be submitted to ROAR for approval.
Still chasing your damn Awesomatix cars here...LOL
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-24-2013, 09:44 AM   #118
I don't understand, does this mean it cogs no matter what the timing is? Or something else?
Art
Old 06-24-2013, 09:53 AM   #119
hanulec's Avatar
Art
Well once they have broken your will -- we can always work out how to get you guys on board . Just what ever you do -- don't turn to offroad j/k
Aaron and Austin have been teaching people about the A700 in nor cal all summer. Region 2 just got a taste of it this past weekend
Old 06-24-2013, 10:02 AM   #120
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
...... Region 2 just got a taste of it this past weekend
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
