Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-23-2012, 11:08 AM   #61
Trader Rating: 2 (75%+)
Can these motors compare to trinity d3 motors?
fung_kyle is offline   Reply With Quote
Old 08-23-2012, 01:04 PM   #62
Trader Rating: 19 (100%+)
Yes, they are much faster. I did back to back comparison with a d3 and a newer revtech and the plutonium motors outrun both of them buy a decent amount.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 08-23-2012, 02:10 PM   #63
these motors are the best kept secret in rc..... shhhhhhhhhh.........
HawaiiBob is offline   Reply With Quote
Old 08-24-2012, 10:39 PM   #64
That would bring your temps down significantly. These motor run comfortable around 140-150 average. Setting the timing to -1 will actually be "absolute zero" where the motor is set now you have 12 degrees of motor timing. Reducing the timing will make it feel softer coming out of the turns and will not have quite the top end that it has now.
Thanks Randy for the info!! So under what circumstances wouild you guys run negative timing on the motor endbell? Other than to bring down the motor temps.
kamenkoh is offline   Reply With Quote
Old 08-25-2012, 02:11 AM   #65
B00t13g's Avatar
What would your recommended starting fdr and timing be for a 17.5 blinky sedan?
B00t13g is offline   Reply With Quote
Old 08-25-2012, 03:09 AM   #66
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
try 3.5 to 4.5
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 08-25-2012, 05:43 AM   #67
I wouldnt run more then the -1 position as with the new sensor board they have bee putting in the motors, that is actually the "absolute zero" position. No problem! Just let one of us know if you need anymore help, more then happy to!
★Randy Banks★
Old 08-25-2012, 05:46 AM   #68
Originally Posted by Craig W View Post
try 3.5 to 4.5
As Craig said, 3.5-4.5 depending on track size, I run a 100x48 track locally and Im using a 4.0 FDR with max endbell timing. For blinky racing it seems that max endbell timing is the only way to go, then you just gear for the temps you need and usually it works out great. Full timing on these motors is 60* Each "hash" mark is 12* positive or negative depending on which direction you you turn it, as on any motor. Hope this help!
-Randy
★Randy Banks★
Old 08-25-2012, 01:04 PM   #69
B00t13g's Avatar
-Randy
Sounds great! Any reccomended temps? Thanks again!
Old 08-25-2012, 01:28 PM   #70
A good average would be anywhere between 135 and 150 for smaller tracks, I pushed mine to 160 average outside just to be able to run faster. The motors have been designed very well and you can push them to upwards of 220 and simply replace the rotor and it'll be just like new!
★Randy Banks★
Old 08-25-2012, 01:47 PM   #71
B00t13g's Avatar
Thank you.
Old 09-06-2012, 01:52 PM   #72
anyone have a base starting point for 13.5 boosted (TC)? FDR, endbell timing, etc. Using a tekin RS. Thanks
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 09-23-2012, 07:51 AM   #73
We ran a 13.5 pluto with a Tekin RS PRO at last years CWIC here in the UK that my son Reece won. we ran the following.
boost- 48
turbo- 10
ramp- 2
throttle profile- 4
delay- 0.1
start- 5k
end- 20k
FDR- 6.84
endbell timing- +2.5
hope this helps
You're only as fast as your father can afford!!!
Xray T3'12- Team Powers XPS PRO 140A- Team Powers Plutonium 13.5/10.5- Team Powers 5600/50c and 6200/60c lipos
www.rcdisco.com
www.team-powers.co.uk
BakerTeamPowers is offline   Reply With Quote
Old 02-15-2013, 05:01 AM   #74
So I'm thinking of replacing my D3.5 with a Team powers 17.5. It will be for boosted .Do these motors fade if the get a bit hot? Does a fdr of 6.65 sound good or should I try something else. It will be on a Speed Passion GT2 pro.
Gerrie is offline   Reply With Quote
Old 05-12-2013, 01:45 PM   #75
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I smoked a motor yesterday during practice (At Tamiya America) and a friend of mine allowed me to borrow his V1 Team Powers Plutonium. I geared the motor at 3.25, set it on the track for the first round of qualifying, and wow, it had some good rip!
I had the timing set at 2 on the can, but with more tuning, the motor could have been even better, which is hard to imagine.
Does anybody know where I can find these motors in the US?
IIGQ4U is offline   Reply With Quote
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
