Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-12-2014, 09:12 PM   #481
Originally Posted by EDWARD2003 View Post
Oh, we don't run the 12.5 rotors in Japan. We throw in a 13.0 mm rotor instead.
What does a 13mm rotor do? Does it make it faster or just more torque?
redbones is offline   Reply With Quote
Old 12-15-2014, 02:32 AM   #482
Trader Rating: 55 (100%+)
I have a team powers actinium. I'm running it in 12th scale and it has to be push started. When starting the main it just sits there for a few seconds and then starts rolling. Once going it's a fast motor. Just doesn't start off at all. All my other motors work fine. I'm guessing sensor board. Anyone else have this issue? If so any help much appreciated
Jamison R is offline   Reply With Quote
Old 12-15-2014, 10:25 AM   #483
Changed the sensor wire and same thing. It needs to be push started. Im running 100mm rollout with max timing. Tried less timing and it did nothing to help.
Old 12-15-2014, 10:37 AM   #484
Could be that or a lot of other things. Check the sensor wire and make sure it is not damaged and check the solder joints at the motors. Both have caused cogging with my motors in the past, as well as bad sensor boards. Also check the current limiter or punch controi on the ESC to make sure you are getting enough current to the motor to get it started.
PS do you have steering when the car is sitting there just before it starts moving?
John Wallace2 is offline   Reply With Quote
Old 12-15-2014, 10:42 AM   #485
This actinium motors are fast!! I tried a 17.5 yesterday and its fast like my $130 R1 premium.
www.ActivRc.com ARC
fx35rc is offline   Reply With Quote
Old 12-15-2014, 11:19 AM   #486
b20btec's Avatar
I have both and the R1 premium is no where as fast overall in 5 minute main. The Team Powers has slightly more fade near the end of the run but it is still faster lap after lap.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 12-15-2014, 11:58 AM   #487
Yes I have steering. Running the hobbywing 1s. Any idea of settings? And my Team Scream works fine with this sensor wire. I have soldered twice. Im 99.9% its sensor board. Just hoping for a little more info.
Old 12-15-2014, 12:03 PM   #488
erchn's Avatar
The 1s had some cogging issues and such, have you tried updating the firmware on your hw?
erchn is offline   Reply With Quote
Old 12-15-2014, 08:00 PM   #489
Trader Rating: 17 (100%+)
I am not famiar with the HW line of speed controls. PM me your info and I will get you a new sensor board in the mail.
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 12-16-2014, 11:15 AM   #490
Yep it does sound like the sensor board. When you said the car just sat there then started up, it sounded like you were getting brown out and the receiver and/or ESC got below it minimum operating voltage and shut off especially with 1C. I've experienced that with my Tekin ESCs and it then takes a few seconds for the ESC to restart before I have motor again. I'm not familiar with the high end HW ESCs either, but if the sensor board doesn't fix the problem check the ESC. BTW I fixed my brown out problem by setting the current limiter on my ESC to 80 amps instead of the default setting of unlimited.
Old 12-16-2014, 11:33 AM   #491
Jamison R Please try turning your throttle curve to custom and changing the bottom to start at 15-20% This should get rid of cogging at bottom end of throttle.
Team Powers, SMC racing, Boca Bearings, Norcal hobbies
James321 is offline   Reply With Quote
Old 12-16-2014, 04:28 PM   #492
EDWARD2003's Avatar
Does the V1, V2, and Actinium use the same sensor board?
EDWARD2003 is offline   Reply With Quote
Old 12-16-2014, 10:43 PM   #493
Gridworks Racing's Avatar
I've been saying this for so long. The Team Powers motors are definitely right at the top of best spec motors and they are reasonably priced.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 12-17-2014, 11:29 AM   #494
DesertRat's Avatar
After doing a little bending around of my sensor board my Actinium 17.5 now reads perfect on my motor checker, each phase is exactly the same number of degrees of advance. I wonder if it will help as much as we seem to think...
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-17-2014, 12:08 PM   #495
b20btec's Avatar
Just wondering how you determined which way you had to go. Was this visually, kinda like bending the sensor tabs until it looked right? My motor phases are off a few degrees and I was wondering if it's even with it to try.
Soap
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
