Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-10-2014, 01:36 PM   #451
Originally Posted by John Wallace2 View Post
I've had some way off too (not team Powers stuff). Won't menti0n who, but I just ordered a couple of new sensor boards, hopefully one of those will have the sensors better aligned.
So why don't you just fix the boards you have?
Rodney Racer is offline   Reply With Quote
Old 12-10-2014, 02:21 PM   #452
If I knew how I probably would.
John Wallace2 is offline   Reply With Quote
Old 12-10-2014, 02:58 PM   #453
tobyzhang's Avatar
I'm kinda interested too whether you should or can fix misalignment in the sensor board. This way we can maximize performance from any board off the shelf. just a thought.
tobyzhang is offline   Reply With Quote
Old 12-10-2014, 03:21 PM   #454
JayL's Avatar
3 SMALL solders on the sensor....
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 12-10-2014, 03:41 PM   #455
DesertRat's Avatar
If you can do that, you have really, really steady hands and good soldering skills.
I am quite confused how it could be out 20 degrees, my board has one sensor that is out 2 degrees and you can tell which one it is by looking at it. If the sensor is really out 20 degrees it must have fallen off the sensor board.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-10-2014, 03:42 PM   #456
wingracer's Avatar
Trader Rating: 23 (100%+)
I don't know myself but I have heard that hall sensors are VERY sensitive to heat and easily killed when soldering.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-10-2014, 03:51 PM   #457
EDWARD2003's Avatar
I'll have to tear apart the motor and check the sensor boards and take a picture. As for performance on the track it has gobs of torque and power. Regardless of it's on track performance, I'm not to sure if the overall performance is diminished by the timing sensors being out by so much.
EDWARD2003 is offline   Reply With Quote
Old 12-11-2014, 12:19 AM   #458
EDWARD2003's Avatar
Here is a picture of the sensor board.
Old 12-11-2014, 09:08 AM   #459
JayL's Avatar
what exactly do you mean by '20 degrees off'??
Do you mean one of the sensors if off by 20 compared to the other two sensors?
or
Do you mean you used some device to measure the timing and it read 20 different than what you expected based on the endbell?
or
Old 12-11-2014, 09:18 AM   #460
I'm thinking on a small variance you probably don't even have to unsolder the sensor, but at 20 that one should be hanging off the pad almost. (doesn't look like it though?)
Old 12-11-2014, 11:13 AM   #461
b20btec's Avatar
or
or
I think that's what he means, his zero on the endbell is 20 degrees on his g force checker. I thought his statement originally was 20 off per phase.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 12-11-2014, 03:44 PM   #462
Trader Rating: 17 (100%+)
-4 = 20
0 = 40
+4 = 60
All plus or minus a couple of degrees.
We have not sold a Plutonium since last November in the US. We have never carried the V2 as it was never sent in for ROAR certification.
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 12-11-2014, 03:49 PM   #463
EDWARD2003's Avatar
Sorry, should of been more specific. The problem is phase A is 47 , B is 37 , C is 27. I tired using the motor checker again and the motor will not produce any timing readings since they all read "OUT." Regardless of where I sent the timing on the can it produces the same readings stating "OUT.". No, it's not the motor checker. I've tried other motors to make sure.. Yes, I used a fully charged battery pack... Also, it will not operate when doing the KV/RPM check. The motor sensor board is toast, it was obviously damaged during the manufacturing process. There are two sensor pickups that show burn marks from a soldering iron.
Just need to figure out how to get this replaced...
Old 12-11-2014, 03:55 PM   #464
DesertRat's Avatar
My suspicion: your sensor board is bent on the tines and not centered on the rotor. Try bending it back in the direction of the B sensor, this will advance the C sensor and retard the A sensor without changing the B sensor in its receiving of the signal.
Old 12-11-2014, 03:58 PM   #465
EDWARD2003's Avatar
Thanks for your advice Desertrat. However, I might just send it back to the hobby shop and get a new one. I don't think bending it will fix the problem, but I do appreciate your suggestion. It's hard to notice in the photos, but the sensors show damage from the soldering process. If you look at IC2 and IC3 on the board, you'll see the damage.
For the one time I tried it out on the track I was impressed. I'll definitely get another one for sure.
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
