Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-04-2014, 09:34 AM   #436
JayL's Avatar
John: ok so say at zero timing it does 20,000rpm and max timing it does 27,000rpm, you are saying it takes longer to get to 20,000 under max timing OR it takes longer to get to 27,000?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 11-04-2014, 10:01 AM   #437
DesertRat's Avatar
Jay, you have to remember that when a motor is on a dyno it's like having it in a car with a non-adjustable gear ratio, fixed weight, and no aero resistance. A motor at high timing will have less bottom end torque and therefore will spin up slower due to having less torque to overcome the weight of the flywheel, it will take more time to spin up to its power band, and the machine will record this as having less torque and therefore less power at low RPM. BUT it will have more torque at the top end and will spin more RPM, so the peak power (torque*RPM)/(Power Constant) will likely be higher, at a higher RPM, and with less torque at that peak power number.
Think about it this way, a motor at an optimal high timing mark will have 20% less torque than a motor at low timing, but will make peak power (with 20% less torque) at a 30% higher RPM number. By running a 20% lower gear in the car, the car still accelerates as fast as the lower-timing setting, but because it can spin 30% more RPM, you gained top end power and speed.
So the answer is yes, it will take longer to get to 20,000 AND longer to get to 27,000, but in doing so it will have done more work (extra 7000 rpm) to get there and the machine will have recorded more peak power and more area under the curve, making the high-timing setting better (on paper) than the low timing mark.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 11-04-2014, 01:23 PM   #438
Trader Rating: 17 (100%+)
Pick a RPM, let's say 13,000. Set timing to 2. See how long it takes to reach RPM. Move timing to 4. See how long it takes to reach RPM. Draw your own conclusions from there.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-06-2014, 11:55 AM   #439
Sorry,what about 12.7 stator in 13.5 plutonium?
Pigio
Pigiolino is offline   Reply With Quote
Old 12-03-2014, 07:44 PM   #440
big al's Avatar
What kind of performance gains, if any, might I expect it I were to put a 12.5mm rotor in my plutonium 17.5? Stock is 12.3mm. The motor is already a beast, but a little extra never hurts..
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 12-03-2014, 09:22 PM   #441
Gridworks Racing's Avatar
You will see a noticeable increase in torque.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 12-04-2014, 01:59 PM   #442
Sort of both. The plot line (rpm Vs time) crosses for zero timed and max timed motors. For my 21.5 TPS Motor (same motor dynoed at at different timing), initially from a dead stop the zero timed motor accelerates faster than the max timed motor. Then the lines cross over at ~0.4 seconds and from that point on the max timed motor accelerates faster. The max timed motor does get to the max RPM of the of the zero timed motor (10.5K RPM @ 5V) about 1/2 second faster than the zero timed motor does, but still takes another 2 seconds to get to its max RPM (15K RPM @5V).
John Wallace2 is offline   Reply With Quote
Old 12-04-2014, 03:08 PM   #443
erchn's Avatar
Just curious, does the dyno put the motor under any sort of load?
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 12-04-2014, 03:34 PM   #444
wingracer's Avatar
Trader Rating: 22 (100%+)
Judging from the numbers he mentions it sounds like a flywheel dyno so yes, the load of trying to accelerate the flywheel.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-04-2014, 03:44 PM   #445
tobyzhang's Avatar
So what is the difference between the PLUTONIUM v2 and the Actinium motor? 12.3 vs 12.5 rotor and that's it?
tobyzhang is offline   Reply With Quote
Old 12-04-2014, 05:49 PM   #446
hanulec's Avatar
Trader Rating: 23 (100%+)
Actinium is roar legal. The other isn't. You want the actinium....
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-04-2014, 06:38 PM   #447
Yes its the Fantom Dyno (AKA Facts Machine II not to be confused with the Facts Machine 2) with the aluminum flywheel.
Old 12-08-2014, 05:29 PM   #448
EDWARD2003's Avatar
Bought a Plutonium V2 and put it straight on a motor checker and the A/B/C sensors were way off.. Really bad. Like ~20 degree discrepancy between sensors. Has there been issues with the V2 sensor boards before? I took it out on the track and it hauls like no other motor, but a little concerned with the sensors being off.
EDWARD2003 is offline   Reply With Quote
Old 12-09-2014, 02:29 PM   #449
b20btec's Avatar
Originally Posted by EDWARD2003 View Post
Bought a Plutonium V2 and put it straight on a motor checker and the A/B/C sensors were way off.. Really bad. Like ~20 degree discrepancy between sensors. Has their been issues with the V2 sensor boards before? I took it out on the track and it hauls like no other motor, but a little concerned with the sensors being off.
20 degrees that's horrible, I was complaining about 4 degrees.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 12-10-2014, 01:09 PM   #450
I've had some way off too (not team Powers stuff). Won't menti0n who, but I just ordered a couple of new sensor boards, hopefully one of those will have the sensors better aligned.
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
