Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-20-2014, 12:55 AM   #376
Soap and I both ran the Team Powers 21.5 in the USGT class at the big EOS race here in San Antonio last Sunday. We both ran Max timing but different FDRs (4.0 and 4.4) on a big track but not as open as we had in the past. I was using my back up car, which was far from perfect, and still was 1.5 seconds a lap faster than the day before with a very good practice motor and my primary car. Really liking the Team Powers motor.
John Wallace2 is offline   Reply With Quote
Old 09-22-2014, 10:07 AM   #377
JayL's Avatar
so which FDR/timing did you like most?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 09-22-2014, 03:48 PM   #378
b20btec's Avatar
I will only speak for myself, I was able to get second place with my FDR.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 09-22-2014, 03:52 PM   #379
erchn's Avatar
Which we will assume is the 4.4, since he mentioned "Soap" first...
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 09-22-2014, 04:48 PM   #380
JayL's Avatar
4.4 wow
What size is the track.
I was told to go 4.1 at my track with 170' straight
Old 09-22-2014, 04:54 PM   #381
erchn's Avatar
4.4 wow
Just so you know, JayL. I'm subscribed to a thread called "Whatever JayL is subscribed to". New feature, hard to find. :-)
Old 09-22-2014, 05:29 PM   #382
b20btec's Avatar
I was running 4.0, he was running 4.4 FDR.
Soap
Old 09-23-2014, 06:08 AM   #383
TEM
TEM's Avatar
Default Plutonium vs. Actinium for mod TC?
Plutonium vs actinium for modified TC? Anyone used both and can tell me the difference?
TEM doesn't advertise for free! Does anyone else notice that a LOT of companies are not even packaging decals with their products?
TEM is offline   Reply With Quote
Old 09-23-2014, 08:00 AM   #384
erchn's Avatar
I've have run both extensively. The Plutonium is a good motor that responds to timing/turbo boost very well. The Actinium is a faster motor that has a bit more rip on the bottom end so being careful with the amount of timing boost you run is a good idea, then tune turbo boost to your desired top speed.
Let me know what speed control you are running and I can help out with a setup for either.
FYI, I've run a 4.5t Plutonium/Actinium and a 5.5t Actinium in mod TC.
Best,
Ethan
Old 09-23-2014, 08:17 AM   #385
TEM
TEM's Avatar
Best,
Ethan
Thanks Ethan! I'll need to get off my butt and order one first. Will be a few weeks before I get on the track with one. I run Orca and SP GT2.0Pro for mod. The track isn't huge and I've run with and without boost with various 4.5 and 5.5t motors, lap times are the same at the end but some setup is better for "racing".
How long is your track's straight? What is the typical motor timing setting and FDR for the 4.5t actinium for non-boosted? boosted? also what does your esc settings look like for boosted?
Old 09-23-2014, 08:36 AM   #386
erchn's Avatar
On the Actinium I generally run an 8.0 final, this is on tracks varying in size from 100' straight to 150'. I usually just adjust the amount of turbo I run or my end point on the radio. I do happen to have settings for the GT2.0 pro.
I'd run the following:
Version: v3.0_120428STOCK (software)
1: for/brake
2: custom/18 (drag)
3: 2.8V
4: 2 (ddrs)
5: 100
6: 25
7: drag
8: 9%
9: 5 (boost)
10: 3 (slope)
11: Disable
12: 8 (turbo)
13: 7000 (turbo start rpm)
14: 0 (delay)
15: 700
Note, I also run -1 physical timing on the motor, which is -7 degrees. I find it smooths out the bottom end a bit more. This is especially important on any of the Hobbywing variants, as they add static timing when boost is enabled.
Old 09-23-2014, 08:41 AM   #387
erchn's Avatar
I meant to also say that for a shorter track drop the turbo as needed to go slower. The bottom end should stay smooth enough. You can also drop your EPA (on radio) to 90 without touching the turbo, which should keep the speed control from hitting turbo range on tracks that are pretty short.
Old 09-23-2014, 08:56 AM   #388
TEM
TEM's Avatar
1: for/brake
2: custom/18 (drag)
3: 2.8V
4: 2 (ddrs)
5: 100
6: 25
7: drag
8: 9%
9: 5 (boost)
10: 3 (slope)
11: Disable
12: 8 (turbo)
14: 0 (delay)
15: 700
Ethan,
What FDR and motor timing for non-boost say for just mod software? What should the motor temp after a run?
Setting for slope; 3 as in setting #3 for 12deg/0.1s or 3deg/0.1s?
I'm actually surprised the fdr is so low. I shouldn't question since I never used this motor but comparatively speaking on a 100' track I typically run high 8's to low 9's for FDR both boosted and non-boost mod 4.5 to 5.5t. SP/LRP/ORCA.
Thanks,
TEM
Old 09-23-2014, 09:01 AM   #389
erchn's Avatar
Ethan,
Thanks,
TEM
I haven't run regular mod software in a long time, I don't remember if it even has turbo. My motors usually come off at about 170 degrees Fahrenheit. Slope is 3deg/0.1s.
The Powers motors like higher RPM, and don't usually have a ton of bottom end, so a lower FDR seems to work better. That said, I ran the Plutonium at 8.4 for quite a long time and it worked fine also, just adjust other settings to get the speed you desire. Given a 100' track, running a higher FDR is certainly reasonable.
Old 09-23-2014, 09:59 AM   #390
JayL's Avatar
Ethans mod motor had insane but smooth rip at the last race, totally copy what he does he had rip on EVERYONE!
Yes, I know Ethan don't make me post in the xray threads
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
