Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-02-2014, 09:08 AM   #211
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Originally Posted by b.wihardja View Post
4,4 and 4,6 fdr for 13,5 boosted? I'm running 6,4 fdr for 13,5 boosted sedan and it' s already hot, around 100celsius, no acceleration too against competitor.
Blinky
IIGQ4U is offline   Reply With Quote
Old 03-02-2014, 10:28 AM   #212
daleburr's Avatar
Reduce your boost and gear up, the Powers doesn't like too much boost but doesn't mind a big pinion.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 03-15-2014, 03:27 PM   #213
So im running a 13.5 nust got the xps 40amp that comes with programming card what are the good setting for.like punch % voltage cutoff, and timming and.juat basically he whole deal just getting into racing my 1/10 scale b4.2 2wd buggy. Any info.would.be.amazing thanks
IRIEirieIRIE is offline   Reply With Quote
Old 03-15-2014, 04:36 PM   #214
Trader Rating: 27 (100%+)
Just wanted to say I've had really good success lately with a v2 17.5 with a HT rotor in blinky against local guys with d3.5s. I'm geared at 3.88 on a medium sized carpet track with timing at about 2.5/4 and the motor kicks like a donkey outta corners and screams down the straight.
Currently, ive gone .3 faster than any other stock guy and my fast lap is equal to a couple of mod guys' fast lap. The best part is it only comes off at 130! Blisteringly fast and runs cool? Seems like the perfect motor!
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-17-2014, 09:43 PM   #215
as you suggest, I currently use fdr 5 and was looking for a proper boost and turbo setting
b.wihardja is offline   Reply With Quote
Old 04-28-2014, 07:27 PM   #216
hanulec's Avatar
i'm excited to run my ACTINIUM 17.5t motor this saturday. keeping my fingers crossed over....
the weather. i know the motor will be good once we find the sweet spot...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-28-2014, 08:33 PM   #217
Bit of an old post but which rotor were you using dale?
We found the exact opposite with the standard rotor.
frozenpod is offline   Reply With Quote
Old 04-28-2014, 09:01 PM   #218
Trader Rating: 17 (100%+)
Start about 3.7fdr.
Art
Oh, and leave the timing on 4.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-28-2014, 09:08 PM   #219
hanulec's Avatar
Originally Posted by Advil View Post
Start about 3.7fdr.
Art
Thanks Art. I have my old 'tricks' from the Plutonium that I might start with first...
Old 04-28-2014, 11:01 PM   #220
The v2 Plutonium looks almost the exact same as the Actinium. Any of you guys know the major changes between the two?
Old 04-28-2014, 11:07 PM   #221
Gridworks Racing's Avatar
It's ROAR approved, has a smoother power band, better braking, and sample variation has been greatly reduced.
This is another solid spec motor.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 04-29-2014, 12:47 AM   #222
daleburr's Avatar
Standard rotor. Fastest setup I found was max endbell timing, about 50 steps/degrees of ESC boost and 5.9FDR. This was on a mid-size outdoor track (WLRC in the UK). I did try more boost and a higher FDR, but it was slower over a lap and had more heat/dropoff.
Team Xray
Old 04-29-2014, 08:18 AM   #223
Be careful Mike. It has a completely different stator and comes with a 12.5 rotor standard. Old tricks may not apply...
Art
Old 04-29-2014, 08:21 AM   #224
The can has been modified to meet ROAR rules, the stator is a little thicker and the wire is a little bigger. Also this motor comes with the 12.5 rotor as standard.
Not sure what rotor came in the V2 as it was never submitted to ROAR for approval and was never brought into the US by the Distributor.
Art
Old 04-29-2014, 08:26 AM   #225
Jorge T's Avatar
V2 had the 12.3mm rotor
RSD MS
Jorge T is offline   Reply With Quote
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
