Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-15-2013, 12:51 PM   #196
Trader Rating: 27 (100%+)
Just kidding, I found some that fit. It was quite odd though. Some of the shim really were too small to fit onto the shaft.
I removed the o-ring completely and added what looks like a .3 or a .5mm (I'm leaning towards .3mm) and it was exactly the amount of play I thought was necessary. Thanks for the tips!
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 12-15-2013, 04:15 PM   #197
erchn's Avatar
No problem, good luck.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 12-15-2013, 08:15 PM   #198
Is the 12.5 rotor the only tuning rotor available or is there others?
Friulimotosport is offline   Reply With Quote
Old 12-16-2013, 04:41 AM   #199
Mr RCTech's Avatar
There are others:
http://os.3racing.hk/products_list.p...atalog_key=103
Mr RCTech is offline   Reply With Quote
Old 12-16-2013, 05:04 AM   #200
Can someone clarify what rotor comes with the V1 13.5 and 17.5 motors ? The TP website says motors between 10.5 and 17.5 come with 12.3 but I see ads for 17.5 motors with both 12.3 and 12.5. If that's the case...what are the item numbers for the motors with 12.3 ? What are the item numbers for those with 12.5 rotors ?
Maybe someone could lead me to a dealer site that actually has some defined info ??
rctrackman is offline   Reply With Quote
Old 12-16-2013, 02:54 PM   #201
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
All of the spec motors have 12.3mm rotors installed.
IIGQ4U is offline   Reply With Quote
Old 12-16-2013, 05:57 PM   #202
Trader Rating: 49 (100%+)
Which motor would you run in 17.5 1/12, the 12.3 or 12.5 rotor and rollout/timing for a 80x36 semi technical track?
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 12-21-2013, 10:54 AM   #203
Pittsdriver's Avatar
What would be a good rotor to increase power in the 13.5?
Pittsdriver is offline   Reply With Quote
Old 12-21-2013, 12:05 PM   #204
IIGQ4U's Avatar
Thumbs up
For me, the Team Powers 13.5 was underwhelming with the 12.5mm rotor.
I race on asphalt and find the included 12.3mm rotor to be superior to the 12.5.
I generally crank the timing, gear it between 4.4 and 4.6 and it's golden. The motor pulls very well and has great top end.
Old 12-23-2013, 10:34 PM   #205
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
Don't race indoor much but I am getting ready for Snowbirds. What is everyone running for a good 17.5 Carpet motor setup with the V1? I have always had good success with shimming the the stock motor properly and everything being really good. Is the Bigger rotor a lot better on carpet or should I stick with the stock setup?
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 12-23-2013, 11:12 PM   #206
I think that generally you'd want a high torque rotor on the small/medium sized carpet tracks so you can get more rip in the infield rather than bolting down the straight.
If you have a pretty dialed setting though, I'm sure that's just as good
Old 01-10-2014, 12:27 PM   #207
Does anyone know where to order parts for the Team Powers motors? I need a new end bell for a v2 (although I think a v1 end bell would fit) and I can't, for the life of me, find out where to order one.
Old 01-10-2014, 12:44 PM   #208
Gridworks Racing's Avatar
We will be carrying Team Powers motors and parts on our Web site soon. We do have the V2 sensor board in stock.
Oops, just noticed you said end bell. I will check to see if I have any available.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 01-10-2014, 02:17 PM   #209
Cool, I'll be waiting to see if you have one in stock.
Old 03-02-2014, 07:11 AM   #210
4,4 and 4,6 fdr for 13,5 boosted? I'm running 6,4 fdr for 13,5 boosted sedan and it' s already hot, around 100celsius, no acceleration too against competitor.
b.wihardja is offline   Reply With Quote
R.A.B. Hobbies venom54 Australian Racing 423 12-18-2016 03:30 PM
Racecraft News Kylelim Singapore R/C Racers 145 02-11-2014 07:53 PM
NEW Bruhsless Motors from TEAM POWERS schmutz Electric On-Road 15 02-05-2011 03:31 PM
