analouge servo, for specktrum
Will a DX3R run a analouge servo...
Yes it will but only with the lowest framerate setting which I believe is the 16mS setting. There are 3 settings, maybe th middle setting wil work also but the fastest for sure not.
All servos are basically analogue.
The only real difference is that digitals servos are programmable regarding failsafes etc.
With the modern tx and rx's you don't really need digitals anymore IMHO
I run a ko pro 2173 fet servo in my rallycrosser which is analogue.
I also run a dx3r and a lipo with no regulator and at 5.5ms and i have never had issues.
So the answer to your question is yes no problem mate.
Just my thoughts.
Jamie.
Just my thoughts.
Jamie.
Just my thoughts.
Jamie.
Just my thoughts.
Jamie.
Was going to try the Hitec 645 servo,, for throtle and brake,,
it states in the manual you can run analogue but like others stated at the lowest frame rate
Should be able to use an analogue servo on the middle frame rate setting. I’m not just guessing, I’ve done it.
If you select too fast of a setting it will be fairly obvious right away, the servo will chatter a lot and not respond correctly.
