Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-26-2014, 04:48 PM   #91
Can u find a ppm signal from a trainer port ? It seems all these modules require is 5v+ so power from battery and a ppm signal found from a trainer port ?
mattst is offline   Reply With Quote
Old 06-07-2017, 02:11 PM   #92
Just want to thank you for this. Found my mars from years ago and just completed the conversion. Just be careful if trimming the board down on the side you solder the wires. I took a little too much off andd had to solder a jumper wire in. Otherwise cheap 2.4g setup.
dangles is offline   Reply With Quote
Old 06-07-2017, 06:44 PM   #93
reptile's Avatar
Trader Rating: 138 (100%+)
Hi what 2.4 system did you use with yours?
HOME OF THE CUSTOM MADE COLORED RADIO WHEEL GRIPS
" PPR REPTILE GRIPS "
THE BEST YOU CAN GET!
reptile is offline   Reply With Quote
Old 10-12-2017, 08:41 PM   #94
Default Burn 12K resistor
Hi I'm from Indonesia, I've been use this mod for couple of years on my ko propo mars and it's work great. But now my throtlle and steering signal is dead, the module bind to the receiver but there is no signal received on the servo and esc. I try to use the fm module and rx and have the same problem. So i open the flysky module and it turns out the 12K resistor was burn out. So I guest the voltage bypass to the ppm. Now I have ex1 ur and I have a plan to doing this mod again, but I'm afraid the same thing will happen again. Has anyone ever experienced the same thing or is there any explanation why the 12K resistor burn out?
SAKWHY is offline   Reply With Quote
