Airtronics MT4 Pistol radio w/telemetry
#1036
The Yeah Racing Wheel is slightly bigger than the original. I can't notice the difference really
#1037
Is there a drop down wheel kit available for the MT-4? I know that a company was considering it but abandoned it due to lack of interest. I used an M8 for several years, then decided to buy a new MT-4. It's a great transmitter, but I'm sooo used to the wheel position on the M8 that this MT-4 feels awkward.
#1038
It looks like the M12 drop down kit will fit the mt4 when that finally comes out?
#1039
I looked briefly through the thread and didn't find anything on this.
Have any of you had problems losing the neutral point on your radio? Mine has been loosing the neutral point on the VR Adjust (i.e. Variable Rate Adjustment), setting it to something other than zero (or close to zero). This, without further explanation, is no bueno. If you've had this issue, is there a fix besides recalibrating the VR Adjust?
#1040
I saw mention of that somewhere. If that is true, I hope it's available soon and for a reasonable price. I'm starting to wish I'd have just picked up an M11 and continued using my Spektrum module and receivers.
#1041
MT-4 with RX-461 reciever and Novak Hovak 540 motor and ESC.
My radio trigger in the neutral position is now the full throttle and what would be the normal full throttle (fully squeezed trigger) is now the neutral position. I hit a small puddle, the truck came to hault. After it dried a short time later it was in this reversed trigger position. Any way to reset it?
#1043
#1044
#1048
So did you replace your radio and reciever? I knew since everything still worked that it must have been some kind of reset that needed to be done, I just didn't know exactly until I posted. Everything works as it should once again
#1049
Your issue may have been slightly different than mine. Sounds like yours could have been a speedo issue. Mine was an issue on at least two seperate vehicles and consisted of my radio resetting the neutral point (under the radio's VR Adjust setting). The resetting of my radio's neutral prevented a recalibration of the speedos and required a recalibration of the radio itself. Unfortunately, the radio recal did not hold. I'll get my new radio up and running today. I got another MT-4. Great little radio despite the small issues I've had of late. I've used the heck out of it - at least 250hrs of racing use.
#1050
That's good to know that these radios are that reliable. It was reccommended that I buy one of these and with all the people I see using them at the track I'm glad I did. As with most electronics there's bound to be issues. Mine is still very new and I'm still learning the relationships between the different components and having fun in the hobby at the same time.
