Airtronics MT4 Pistol radio w/telemetry
#1891
Right, the AA's work fine but the Li-Fe doesn't... that pack should be more than up to the task.
Maybe you did get a pack that has a loose internal wire or a loose connector wire, but that's not to say that all nano Li-Fe's will have the same issues as yours.
The good thing is that it was probably $8 and dealing with HK on a return is not worth the time. I would just order another one from them or elsewhere... maybe the nano 1.5a 20c Li-Po that I have have ran for the past couple years.
Or stick to AA's but after you have use a Li-** 2s pack... hard to go back to AA's.
#1892
is more of a connection issue, please re-check all connection sw/servo/rx, is all good then it might be rx got shock, put some sponge to protect it. i myself experience it with mt4s+rx472. hope it helps
#1894
#1895
My MT-4 will be arriving today. It will be the much overdue replacement of my DX2.0. I am pretty geeked about it.
#1896
Update to my brake issue with mt4 and Novak gtb2 esc. I used my friends mt4s to sync to rx, did one touch program on esc. Brakes worked great on stock esc setting. Double checked radio settings and re sync the mt4 and brakes would not work. The mt4 works with my Novak impact in 22 buggy and Novak active8 in mbx7 eco. It does not seem to like the gtb2. I sold the mt4, who is using it with speed passion esc and it is working good. I purchased mt4s and it works with all my Novak esc. Anyone else using the mt4 with gtb2 with success?
#1901
hey guys can somebody help me out so I just got a light swith for my led bar so I can turn it off during the day instead of having it on all the time when I turn on my car and I'm just trying to figure out what button or setting to go to so I can turn the light on from the remote I have the 92524 reciever if that matters
#1902
Afair you need additional module to do that. Dig something like rcmart for 'light control'
#1903
I was wondering if anyone has had issues with trim on there controller. I have had issues lately with my servos not centering and originally thought it was the servos so I have changed them and then changed receivers with the same result it wont stay straight. so im at the point were im thinking its the controller
#1904
Not to ask a stupid question or imply you're doing something wrong, but are you sure you aren't accidentally hitting the trim buttons? They are strategically located for easy access, and accidental access if you aren't paying attention
Personally, I have 5 vehicles and 3 different types of receivers, haven't seen that issue (not to say it's impossible).
#1905
