Airtronics MT4 Pistol radio w/telemetry
#1817
Weird question.
EPA is a must in all channels where servo exist.
Expo - i'm using one on my ebuggy' brake channel to achieve desired feel
D/R useful to calm down oversteer, i'm using it on both buggies
#1820
Yes, and batt consumption also SHR mode. My nimh ep1600mah can only ran for 4-5 tanks
#1821
Might sound stupid but I was wondering if you could use a micro air receiver on the mt4? I want to use it on my crawler so range is not an issue.
#1823
I'm not concerned about range. I'm only ever 20' away from the crawler. My reasoning is the size, weight, and cost of the micro air receiver would fit my needs best if it compatible with the mt4.
#1824
The stock receiver is very small and practically weightless. I can't answer the air questions unfortunately.
This is about as small as I've seen:
http://www.amain.com/Airtronics-24GH...ceiver/p150528
#1825
Most (all?) radios air/surface systems don't communicate with each other. Maybe check airtronics website and see if it mentions that on the receivers page. Pretty sure they are still in California with a phone number too. Best to make sure before you buy.
An example from one of their air receivers, if I'm not mistaken those are both air transmitters...
The RX600 (92224) 6-Channel 2.4GHz FHSS-1 Mini Receiver is an affordable full-range receiver that is compatible with Airtronics RDS and SD series transmitters
#1828
Has anyone used the RX-462 receiver with external voltage sensor to monitor a 4S setup? I have blown the inline fuse of my sensor three times now and two of them just by connecting the main battery cable, didn't even run the motor.
I think the fuse blows by the large inrush current when connecting the batteries but it's strange they would design the system to not be able to handle that.
Have anyone tried bypassing the fuse or replacing it with another?
#1829
#1830
And your setup is just like in the manual, connect the sensor wire (with fuse) to battery positive?
What ESC:s are you using? forgot to mention that in my last post, I use Hobbywing XERUN 150A and have connected the sensor wire to the ON/OFF switch which has a direct connection with battery positive inside the ESC so I can't see that makes any difference either.
