DX3R PRO 3CH DSM2 Racing System by Spektrum
#46
The lighting lights up the whole screen and will dim itself back to normal when no buttons are pressed. It's an LCD screen and the lighting does not look to be LED at all. It looks to be more of an EL backlight.
I haven't disassembled my radio to truly know, but I've seen LED backlights before and this doesn't look like one. It lights just like a 3pk/4pk where the it glows the whole screen... but in white. Looks blue in the photos, but mine is pre-production so not sure if has been changed.
#47
Yep Im in the market too and I just cant get past the looks of this thing. I have heard nothing but good things about these radios but Spektrum has never had original or good looking radio, they just look very cheap to me (price tag says different though, lol).
Features wise, sounds like a great deal though!
As far as price it's cheaper than a 4pk , M11x and a KO.
#49
Can you clear this up. If I can use the marine reciever (MR200) on this radio which is compatible with my DX6i airplane radio. Does this mean I can bind this radio to my airplane reciever?
#50
R/C Tech Elite Member
Thanks for the reply Shreff and good luck at the Birds this year. I have one more question and it's regarding the ABS feature. I know a few people who have used this feature with other radios and some have had issues with the ABS burning up servos due to the rapid transit rate. Are there specific servos you "should" be using to take advantage of this feature or maybe has to at least have some kind of minimum spec requirements? Oh yeah... is an idle up feature something that can be added in the future via the SD card?
#52
I've never had an issue with servos burning up with ABS, but this is where properly setting your endpoints makes a huge difference too. If you're worried about it I would suggest using a servo with an aluminum case to give a little better heat dissipation such as the Spektrum S6040.
#53
Orignal as in using the same case JR was using when Spektrum first came out. Thats what I remember when I hear spektrum. I understand its cheaper than the radios you listed, I merely said it LOOKED cheap to me but the price said otherwise. $200 is not what I would consider "cheap" but yes your right, there are more expensive radios out there.
#54
#55
I won't be at Birds either. Have other things going on that prevent me from going. Really gonna miss it as I've been at the Birds for the past 6 years or so.
#56
.... just now i buy m11x!!!
#57
Here's the link to the drop-down kit for those interested:
http://www.horizonhobby.com/Products...ProdID=SPM9021
#58
Now I am torn. The DX3R has been an awesome radio for me. I loved my M8, but the battery life on these things are amazing and the compact size and weight.
I also added the big grip awhile back and it helped for hand size. In the world of technology: my biggest wish would be a convertible trigger to fit atleast a couple of different angles.
I would love to try the drop down, the grid conversion looked to be of very high quality but now a direct conversion from spektrum may hurt them.
The SD route seems to be how the world is moving. Most high end GPS units, gaming systems, and even my high end radar detector has this feature for updating and holding additional memory-cheaply.
Incorporating the monitoring system also gives this radio flexibility for a wide range of users is a bonus.
#59
