lipo cutoff for an sc18
Afaik, Novak's Smart stop is the only reasonably priced, true lvc available where it will interrupt the power to warn you about low voltage. LRP has one, but its like $70 (not sure its actually for sale yet).
There are several lv alarm (lva) type options, but if you fail to notice these, the lva will let you go ahead and overdischarge. These usually plug into the lipos balance port and are easier to connect.
eBay has a lot of them and COmmonsense RC offers a few as well.
i used the novak cut off on my blitz when i had it and it worked like a dream and I loved it. the only thing i didnt like about it were the instruction arnt exactly the greatest but thats minor
From how I understand it the Novak LVC has 3 connections. One is connected to the battery to monitor voltage, then the other two connect it in-between the RX and ESC. When it detects cut-off voltage it doesn't actually disconnect the battery connection, but cuts the throttle signal going to the ESC.
