Shouldn't make any diff as long as you have a Castle link. If motor runs backwards, you can use the link to reverse it instead of the usual swapping any two of the wires.
This is a sensorless setup; it doesn't matter other than the direction. The Castle links allows you to reverse via the esc if it is backwards the way you have it soldered.
