traxxas vxl-3 low voltage cut off problem
i bought a traxxas slash 4x4 about 4-5 weeks ago and love it.i have run the snot out of it and takes the abuse great! but im experiencing trouble with the stock vxl brushless esc,while running my venom 3 cell lipo it will kick in to low voltage mode after about ten min. into the run.i know the battery still has a good charge because if i try to recharge it,it only take about 2000ma.i also have a 2 cell venom pack and it never has givin me the same problem,i was just wanting to know if i there is anyone out there with this same problem??
yeah that works,but i run a under body cover and dont like to peel it and the body off of it half ways threw the run, and i dont think that is a standard feature of it.....at least i hope not.has anyone ever had luck with traxxas fixing it?
what is the buzzer thing you are talking about?? i have the same issue and don't want to pay to ship my ESC back and be without it and it possibly not be fixed for free...
Here's a few -
http://toys.shop.ebay.com/?_from=R40...arm&_sacat=220
Prob with a alarm is you have to pay attention to it, it is a passive type cutoff - it does nothing unlike a true lvc that either pulses power to the rc or cuts ot off entirely protecting the lipo. You can overdischarge a lipo running an lva.
Showcase, disable the lowvoltage cut-off if you're using a NiMH battery, the LVC is only for LiPo batteries.
fastfxd, I'd either send it back to Traxxas, or;
Cheap Way: Set ESC to NiMH Mode and use a Low-Voltage Alarm (Potentially Risky)
More Expensive Way: Set ESC to NiMH mode and Install an external low-voltage cutoff.
Up to you.
Up to you.
The lvc on traxxas esc's is junk. My friend has 3 of the vxl-3s esc's and they all are set to different voltage cut off points. They can all drive with brand new batteries that are rated the same, and took the same amount of charge and they will all end at different times even if they drive the same and are geared the same. Its not their driving, because we went in and checked the voltage of each battery with a multimeter and they were all like 0.2v apart (not much, but on a 5000mah pack that is a good couple minutes). They switched over to hobbywing esc's on two of the cars, but one of them still has the traxxas. He just runs in nimh mode and when he has to pull the trigger more to get the same speed, he stops and checks the voltage. After doing that many times, he has averaged the time with his driving style it takes for the battery to get low. So he sets his timer on his ipod/phone (whatever he has in his pocket) to 1 min lower than that. When the alarm goes off, he checks the voltage. Normally a little pre mature but better safe than sorry.
