Radio mod for robot sub
I'm building a model submarine with various sensors and other features. The number of controls (channels) I'll need (in the 40 Mhz band,) is quite a lot more than is normally available in a set commercially.
There are obviously a number of options here:
a) buy a commercial radio control set and modify ('hack') it to take the extra channels (in practice, maybe just using the transmitter portion);
b) find an electronics self build rc kit/design and adapt that;
c) find ready made tx/rx 40 MHz modules and use those as the basis for the design;
d) find a commercial radio control set that has provision for an external input with many channels.
Note that I have fair electronics knowledge but to save time and effort and not to reinvent the wheel (also to ensure a legal radio setup) I'd rather invest in a soundly designed tx.
As another issue, it would be very handy to have a bidirectional link, that is, receive sensor and other data back from the sub, again, in the model 40 MHz band.
It's a long time since I have played with model rc, so I don't know the market for this kind of stuff very well. I've found some gear in the 2.4 GHz band range, but this is unsuitable for a model submarine.
Has anyone experience in this area, know a business that offers self build 40 MHz radio kits or have any other helpful pointers?
Duster_360: That's what I'm thinking. In the days of single or double sided pcbs it was fairly easy to trace the tracks and break into the board. Then I could use a cheap two channel set and wire in my own encoder/decoder electronics; problem solved.
I suspect that things are different nowadays with very high density multilayer surface mount boards making that hard work. But like I said it's been a long while since I saw a rc radio set so I just don't know -I was hoping for info from those who use them now.
