Hobbywing Justock esc >
Like Tree4Likes
Old 02-12-2013, 10:33 PM
  #91
izzyracer's Avatar
Trader Rating: 27 (100%+)
I just purchased this to replace my Citrix. I'm hoping it will give me some improvement over it. Will test this weekend. I guess I need to get a program box to upgrade my software, I only have the basic LED box.
izzyracer is online now
Old 02-13-2013, 12:41 AM
  #92
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I replaced my Cirtix with a Justock. Big improvement in my opinion. It was nice to have brakes finally!
Dan is offline
Old 02-13-2013, 02:41 AM
  #93
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by sosidge
There are a couple of stages with the HW software - you are at the stage of updating the LCD programmer. You need to update it to 120504 - NEVER xxxx_v3 for a Justock or V2/V2.1 ESC.
Thanks mate. Got that bit sorted.
Once you have updated the LCD programmer, you will be able to switch over to the ESC and you will find the 508 in the dropdown. Check that the software database is listed as 121204, because that is what the latest version of 508 comes from.
Now I just need to find some time to get this bit done. Didn't have time before last nights race. 3 weeks till our next meeting, so plenty of time........
Sith Lord is offline
Old 02-20-2013, 10:02 PM
  #94
duckman996's Avatar
Trader Rating: 14 (100%+)
I need some help. I have a lcd program card that has the v3 software on it, however, I am not running a v3 speed controller. I am trying to change some programming in blinky mode however, there is no blink (504) software on the program box. Is there anyway to "reset" or delete the V3 software from the program box? When I try to reflash the box with older software, a warning box keeps popping up saying the current version cannot be updated.
I am using a speed passion GT Stock Spec ESC
My program card is the multi program LCD unit
Can anyone help?
duckman996 is offline
Old 02-21-2013, 06:47 AM
  #95
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Can anyone help?
Which version of Hobbywing software do you have installed on your PC? Are you trying to put Hobbywing software on a Speed Passion ESC?
liljohn1064 is offline
Old 02-21-2013, 08:37 AM
  #96
Trader Rating: 64 (100%+)
Can anyone help?
Plug just the LCD box into your computer.
Open your HW software.
In the upper tab, select LCD box.
Go to firmware and load the 2.1 software on the LCD box.
Then it should work.
There's two levels of software for the LCD box that will work the two levels of hardware speed controls (v2.1 or v3.0)
MC112b is offline
Old 02-22-2013, 06:29 AM
  #97
Settings...
I was goofing with one of the F1 cars last night and started playing with Max reverse force on the Justock. I was thinking that since I was running forward/brake only, that this didn't impact my config. I left it at the default 25%, set Brake force @ 100%. Still a tad soft.
Then, I proved my thinking Wrong!
I jacked it up to 100% reverse and now it locks up at the touch of the brakes. I have to turn it back down, but I got it through my head that even if reverse isn't used, that setting does impact braking.
Old 02-22-2013, 06:50 AM
  #98
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Originally Posted by liljohn1064
Settings...
Same thing applies to the v3.
As soon as I jacked the "reverse" strength up...I had brakes..who da thunk it.
j.d.roost is offline
Old 04-16-2013, 03:00 PM
  #99
Gabriel315's Avatar
Could i use the Justock without the fan? I run 2s' only. The problem is it my car is too small and my electric components are a little tight inside the car.
Gabriel315 is offline
Old 04-16-2013, 03:41 PM
  #100
padailey's Avatar
I run mine without the fan in my F1 car.
padailey is offline
Old 04-17-2013, 11:01 AM
  #101
Gabriel315's Avatar
Does it gets too hot? IS there a risk of burning it?
Old 04-17-2013, 11:17 AM
  #102
mkiiina's Avatar
Trader Rating: 71 (100%+)
I have been running mine without a fan in VTA for a few months now without issue. You should be fine.
mkiiina is offline
Old 04-17-2013, 11:27 AM
  #103
vivo quevas's Avatar
Trader Rating: 19 (100%+)
I have been running mine in 17.5 class without a fan with no problems! It has been 85 degrees ambient temp here!
vivo quevas is offline
Old 04-17-2013, 12:10 PM
  #104
theproffesor's Avatar
Trader Rating: 66 (100%+)
I am having trouble downloading the software and am currently using brushless hobbies software to change the settings. seems to be working fine. Does anyone think that there would be an issue with this?
theproffesor is offline
Old 04-17-2013, 12:29 PM
  #105
Gabriel315's Avatar
That's nice! Thank you very much!
