Mains powered transmitter
Hi all
I am new to this site and was looking for a bit of help if possible
Can you tell me if it is possible to run a transmitter off the mains instead of batteries?
Or can you use your transmitter when it is being recharged?
I run a slash 4x4
Thanks in advance
Henry
I run a slash 4x4
Thanks in advance
Henry
If you have a transmitter than has a recharge port on it, you should be able to use it while it is recharging. Test it at home. Just plug it in for a recharge then turn it on and drive the truck. Other than that, I'm not aware of any pre-made way to run one off the electrical outlet/mains.
Why would you want to be connected to mains power while outside playing with your car ?
Grab youself some LSD (Low Self Discharge) nimh rechargeable's and you will have hours of radio time between charging
Some radios will allow the batteries to be charged while still in the radio, radio must be turned off while charging
Cheers
Cheers
Radios that allow recharging batteries while in the radio allow charging only at low rates (usually just a few 100ma) and only with the radio off. You'll do better time wise to get a separate charger for the batteries. That way you're not down for so long waiting for the batteries to recharge.
You can get 2 sets of the LSD type batteries so when one set is used up, you can place them on charge and switch to the other set and continue running.
If thats a Link TX like mine, it doesn't recharge batts in the radio anyway.
