How to charge NiMH AA batteries in a KO EX-10 helios?
Is there a way to charge the AA batteries I use in my EX-10 Helios without removing them from the battery pack that goes into the radio? I notice that there is a charging plug on the back of the radio, can I use that? I notice that KO Propo doesn't advise (states don't do it) to recharge NiMH batteries this way but to use a rechargeable battery pack. So, how do I charge these batteries without buying a AA specific charger?
You don't want to run the risk of burning up the internal wiring or even the circuit board inside the radio.
Pass you soon...
My charger will not charge the batteries thru the charging jack. I believe it has something to do with some type of internal circuitry within the radio most likely a diode. But the real reason you don't want to charge thru the charging jack is that the internal wiring can not handle very much current. the only thing that is recommended is a wall charger that charges at a very slow rate.
Pass you soon...
Pass you soon...
