HELP!!!How can i remove connectors(deans)?
I recently bought a AE B4.1 brushless that came with deans connectors.I use tamiya connectors.How can i remove deans?
I would just convert to Deans, they have much less resistance than Tamiya connectors. They will handle the current that a brushless motor will draw from your batteries much better. Maybe you know someone that can teach you how to solder, it's really a skill that you need for this hobby and it's easy once you know how.
But my batteries-charger-other cars are with tamiya connectors.I will put tamiya for now and maybe i will put deans in near future.
i race tomorrow and i haven't got time to buy deans.
If you're going to a race, it's likely someone there will have a soldering setup. Just ask around for some help, unsolder the Deans from the wires. Do you have Tamiya connectors to use for now?
For the future definitely plan on upgrading connectors soon. As mentioned the Tamiya connectors don't hold up all that well, either to repeated use or much power.
if you are not using hi amp draw motors, then tamiya plugs will be fine. Bear in mind this design has been around for over 2 decades and the pins on both male and female plugs will wear out faster, plus its chromium plated and crimped directly on the wires. no solder to ensure a good flow of electrons through the wires.
trust the good people in the rctech universe. they are speaking from experience. Loose the tamiya style plugs and upgrade them to Deans
If we were racing together tomoro, i dont mind soldering up a pair of deans for you. hope someone will help you on race day
good luck
good luck
Super Moderator
Trader Rating: 31 (100%+)
AE put deans on that car for a reason, too much power for a tamiya style plug!!!
