I am stumped.....HELP!!!
I will try my best to explain this situation. I have a 2wd buggy with a Tekin RS ESC, Spektrum radio and receiver and a couple servos....thats the issue.
My system worked good with a slower HiTec servo, but I decided to upgrade to a faster servo. I installed the servo and when I turned it one direction it would glitch back and forth like crazy and not hold the desired direction. If I turned it the other direction it would hold until I released the steering wheel. I thought this was odd, so I took it back and got a different servo, installed it and the same thing happened. I thought it may be my receiver so I switched that out for a new one and it still does it. I plugged a different ESC to it and it still did it. I rebinded the receiver and radio multiple times. Here is the kicker though...when I put the older slower servo back in there were no issues whatsoever. When the faster servo is freaking out, the green light on the receiver is flashing as if it maybe not able to hold the voltage that it needs, yet this does not happen with the other servo.
I even resoldered the capacitor to make sure that wasn't the issue. About 6 months ago I popped a Capicitor when I cross polarized the wires, but the ESC has worked since then and I have driven a ton.
I could always just keep the older servo, but I know I should be able to upgrade.
Ideas??????? Thoughts???????? Experiences????????? All are appreciated as this has frustrated me beyond belief. Thanks in advance.
This will most likely fix your problem. Fixed the same problem for me.
Spektrum Voltage Protector. Search at amainhobbies.com. Will not let me post link.
