Castle Motor Wiring
Castle Motor Wiring
Has anyone opened up the Castle Motors to solder on new wires? Is it possible to do? Are there solder tabs inside of the can? Pictures would be great if you have any.
Thanks,
P
Thanks,
P
no solder tabs inside any of the motors I've seen. the wires are soldered to the windings.
Thanks for the replies. I opened it up anyways out of curiosity and you're correct, the wires are directly soldered into the windings and then covered over in epoxy or similar. I think I'll just solder on extensions at the 'bullets' end.
