Novak 5.5 HV Problem?
I just purchased a used 5.5 HV motor. I installed it in my hyper 10sc and really seems to be lacking power, both torque and rpm. I am currently using a XERUN 120amp sensored ESC and 2s 25c 5000mah lipos. This ESC has powered other sensorod motors and non sensored motors with zero issues. Also tried with a Traxxas VXL Esc and same issue. I have double checked all the ESC settings and tried the defaults. No noticable difference. None of the wires get hot nor does the motor can . The motor does not cog and seems smooth but just seems to be lacking power.
I took of the front housing to look inside, no signs of burned windings or overheating. One thing I did notice was the rotor magnet seems very weak. In other motors I have took apart, the power of the magnets were extremely powerful. This one seems like a refrigerator magnet.
Any thoughts or advise?
Thanks!
Thanks!
Thanks!
Thanks!
Mine is geared at a 15, if the rotor seemed very easy to remove, the rotor might need to be replaced.
The rotor was abnormally easy to remove. The VXL rotor rips out of your fingers when placing it inside of the can. This one, not so much.
Unless I'm missing something, this motor should be stupidly powerful compared to a 540 canned motor correcto-mundo?
Sounds like you are running only on 2s?
The 5.5 HV (High Voltage) will only produce lots of power if you run it on a 4s LiPo, or 2 x 2s LiPos in series.
It will run fine on 2s, but it won't seem as powerful as the VXL setup unless you get it on 4s.
Note the XERUN 200 will only do up to 3s.
