Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 05-19-2011, 07:45 AM   #1471
psx
Originally Posted by QuangVuong View Post
This is a theory which will work with Channel 3 if that channel is a analogue one. If it's digital it may not work.
I already wrote it. This will work only with support in firmware.
In hardware there is resistor somewhere connected between CH3 button and +5V. Another pin of CH3 button is conneted to GND. And that pin of CH3 button with resistor is connected to microcontroller to ADC pin, so it will be possible to use it in new firmware (after writing code for it).
psx is offline   Reply With Quote
Old 05-19-2011, 02:15 PM   #1472
QuangVuong's Avatar
Trader Rating: 16 (90%+)
Send a message via MSN to QuangVuong
Well, I have the 3 Racing kit and the R2 flashing kit. They both work with the receivers.
GT3B Help? Click here!
http://www.rctech.net/forum/9935672-post2986.html
CS'd Yokomo MR4TC-BD 67% - Reedy Stockstar and Novak GT7 - Bluebird BMS-630MG - GT3B
CS'd Tamiya TA-05F(Fijon) 100% - EZrun 9T 35A Brushless System - Futaba BLS451 - GT3B
QuangVuong is offline   Reply With Quote
Old 05-19-2011, 02:25 PM   #1473
You can add me to the list of people offering firmware modifications. I am based in Portland Oregon (Pacific Northwest).
RobsPics.com - RC Action and Sports Pics (w/ 2011 ROAR Carpet Nationals Pics)
RCBabes.com - Hotties, Cuties, and Product Photography
"A girl’s legs are her best friends, but the best of friends must part." – Redd Foxx
Robs Pics is offline   Reply With Quote
Old 05-19-2011, 03:13 PM   #1474
305
305's Avatar
This is quite interesting, QuangVuong. I have dealed a lot in the past with this problem. From what I know and also have tested for myself, the Flysky 3ch RX (Flysky FS-GR3C) does not work or works very oddly with these LED light kits:
- 3Racing LED Light System
- Ultra Bright LED Indicator Signal Light System (from R2)
- GT POWER Car LED Light System 2.0
- HobbyPro 364 LED System
It is because these light kits are electronically the same, clones. They are suitable for RXs which output signal bandwidth is between 5 to 20ms. 20 to 22ms is a typical output signal bandwith for most common RXs, including the Flysky 3ch. Really, I tested a lot of those LED light kits, so I am surprised, that yours work.
Anyway, if you are looking for a very good LED ligth system (those above are crap), look at this one: http://www.bel-shop.eu/detail909.html There is an english manual available. It is worth those cca 35 bucks.
Est modus in rebus, sunt certi denique fines.
RC.305 - site dedicated to RC cars and scale - http://rc.305.cz
305 is offline   Reply With Quote
Old 05-19-2011, 07:55 PM   #1475
Thanks 305.
I read this whole thread thru, but it's hard to remember all the different tips.
bill_g is offline   Reply With Quote
Old 05-20-2011, 04:52 AM   #1476
305
305's Avatar
Originally Posted by bill_g View Post
Thanks 305.
Yeah, I know... somehow this thread expanded a little in 2 last months
The way you use the STM8S kit impacts the type of programming cable. When you power the radio from USB, you need a 4-wire cable. When you power the radio from its batteries, you need a 3-wire cable.
I do not know for sure now, has anyone tested a 2-wire cable, w/o the RST?
Old 05-20-2011, 05:23 AM   #1477
Default jr charger
[QUOTE=RoughLandin;8924233]
Originally Posted by JMYBFFT View Post
I use an airplane field charger with a hobbico round charge lead, use the +/- that Futaba's use, don't use a JR/Spectrum charge lead as the polarity is opposite. Any NiMH charger will work, just charge at under 1 amp, too high of a charge rate and it will shorten the battery's lifespan. I typically charge at around 0.2 amps over night in the garage. This way it's more like a trickle charger. If am in a hurry I could bump it up to 1 amp but don't like to, it takes about 1.5-2hrs at this rate.
could i just swap the wires around inside the tx on the charging plug so a jr or spectrum unit could be used to charge nimh ? or futaba and jr plugs diff size?
blingg is offline   Reply With Quote
Old 05-20-2011, 08:22 AM   #1478
Default firmware
can any one post me the standard fw so i can see if my card and pc are good to go when the tx arrives ,cheers blingg
Old 05-20-2011, 08:39 AM   #1479
305
305's Avatar
It is useless to have the FW at this time. If your kit is really prepared for GT3B flashing you'll see only when the radio arrives and you connect it to the kit
Old 05-20-2011, 07:29 PM   #1480
2 wires does NOT work.
fixitrod is offline   Reply With Quote
Old 05-21-2011, 08:00 AM   #1481
beemerfan's Avatar
Trader Rating: 34 (100%+)
So I read back through several pages and can't seem to find the post where someone was offering to part-out a "bricked" radio from a soldering job that went bad. I need the potentiometer from the steering.
beemerfan is offline   Reply With Quote
Old 05-21-2011, 04:25 PM   #1482
QuangVuong's Avatar
All links on Page 100
Old 05-21-2011, 04:26 PM   #1483
QuangVuong's Avatar
Links!
QuangVuong Donate-only a few $ per month Would be great, just to keep the pics alive.
If this isn't working, just send a donation to: pavlo_.88@hotmail.com
PSX Donate(TBA)
HOW TO: Reprogram the GT3B Radio
Improve LED Readability in Sunlight
Glitch Buster Capacitor Mod
Lipo/Other Battery Mod
Regulator Mod
Diode Mod
Reptile's GT3B Steering Bearing Mod - Pics here of steering adaptor, which is a KO type wheel. Round with a flat side.
Using the VRC Adaptor
PSX Firmware Generator
Custom Firmware
All downloads are still at the same address:
https://github.com/semerad/gt3b/tree/master/Releases
And beware that You must click at the file first, then other WEB page will show and at this next page select "raw" at the header of file.
New Firmware Help-
FLYSKY GT3b Transmitter
Service Menu
GT3B Review
Insight of the GT3B
Useful links!
PSX
FireFrenzy's Tutorial on Reprogramming the GT3B
STM8S Mod from 305
losikid67 Overkill RC 3pos Switch Adaptor
Preprogrammed GT3Bs and Reprogramming Accessories from OverKill RC
People Offering Reprogramming Services
Australia
NSW
QuangVuong - $5 per radio. An extra $5 for a bearing mod. Plus postage both ways.
America
Arkansas
Smoedog -$5 per radio + shipping
California
Mattyhawk -
$5 to open the radio to do any mod
$10 Recom Voltage Regulator (VR)
$5 Program Radio with Firmware of Choice
$5 Make the radio Lipo ready (suggest VR mod)
$7 Bearing Mod
$5 LED Indicator
$2 Improve LED Readability in Sunlight
$2 Re-program Firmware with Updated Firmware
The Works (VR, Program, Lipo, LED & Bearing mods ): $32**
**(with the "Works" package, will do readility mod for free if you want it)
Return postage paid by customer.
Chicago, Illinois
beemerfan - $10 + all shipping costs for reflashing
Colorado
losikid67 - $10 for first reprogram (will include 4-pin header) and $2 for each additional future program + shipping both ways
Florida
Seth556
$7 for the programming
$12 for the voltage regulator mod (cost of VR included)
$5 for the bearing mod
$4 for the led mod + shipping both ways
Indiana
Fixitrod - $10 plus postage both ways
Jefferson City, Missouri
bugman72 - $10 + shipping for the reflashing service, $5 + shipping for the bearing mod
Robs Pics - $10 plus return shipping
Canada
British Columbia
Kamlooper - $10 plus shipping
Where To Buy the STM8S?
Overkill RC - $25
^This is more expensive as it is a premade kit for you to reprogram your kit without any other accessories.^
element 14-$15.71
Digi-Key-$9.60
Mouser-$9.60
UK Farnell-7.23 Pounds
Micro 4 You Studio-$16
Future Electronics-$8.55
Please PM me if you know any stores, which sell the STM8S board. Please send me a link of the item.
Please PM me with your area and price you are offering to reprogram the GT3B. I will be adding to this list.
If Ive missed your tutorial, or something useful, please PM me and Ill add you here. Sorry if I did miss you.
Old 05-21-2011, 04:27 PM   #1484
QuangVuong's Avatar
All links on Page 100. Please PM me to let me know if you are offering services, etc.
Old 05-21-2011, 04:27 PM   #1485
QuangVuong's Avatar
Sorry for the spam, just reserving top spot on Page 100.
Tags
page 100 for all info
