Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-17-2011, 03:07 AM   #1081
QuangVuong's Avatar
Trader Rating: 16 (90%+)
Send a message via MSN to QuangVuong
Reprogramming the GT3B
First thing is that youll need a STM8S board which costs about $15.
Buy it from here: http://au.element14.com/stmicroelect...ger/dp/1775251 Its the only place in Australia that has them locally.
Then you desolder points SB1 and SB2 Or snap the board in 2.
Then it'll look like this
Or snap along this line. Better to cut it
On my radio, I soldered a 4 pin matrix board(aka 4 way header) to the 4 holes. It saves time from soldering and desoldering the wires. I can just use a 4 port servo plug.
This is how you wire up the radio to the board. Notice how the wires are the same way. Take notice of the positioning.
Ok download the ST Visual Develop software here: http://www.st.com/internet/com/SOFTW.../sttoolset.zip
Open up the programmer after youve installed it
Make sure you have these settings
File then save - save your original file, so you can restore your radio if anything goes wrong.
Then go to file and open. Then find the modified flash software. This can be found at:
http://cs.mff.cuni.cz/~semerad/GT3B/
or
https://github.com/semerad/gt3b/tree/master/Releases
It should load up like so. Then go to program, then This tab
Then it has a progress bar and there will be a message at the bottom saying that it was successful. So I fixed the trim(up to 99 now instead of 30) and added more EPA for more steering lock. without the need of any mods to the chassis.
Theses were my mods: fixed expo, trims set to +-99, 9.6v low voltage, 1 min backlight and 200% max EPA.
Please check out the list on page 99 or 200, for more people who offer this reprogramming service.
GT3B Help? Click here!
http://www.rctech.net/forum/9935672-post2986.html
CS'd Yokomo MR4TC-BD 67% - Reedy Stockstar and Novak GT7 - Bluebird BMS-630MG - GT3B
CS'd Tamiya TA-05F(Fijon) 100% - EZrun 9T 35A Brushless System - Futaba BLS451 - GT3B
QuangVuong is offline   Reply With Quote
Old 04-17-2011, 10:07 PM   #1082
Trader Rating: 49 (100%+)
Anyone stateside reprogramming these radios? I'd be interested for the right price.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 04-17-2011, 10:09 PM   #1083
Firefox's Avatar
Originally Posted by csrcxd View Post
Firefox, do you happen to locate in Kansas..? I don't think "Ks." normally stand for kansas, but if it is...
BTW, would anyone explain what was wrong with the Expo feature? How does it not work? I tested mine, and does change how much servo travels at different degree of knob turning. What am I missing?
Yep !
Tamiya M05, Associated SC10.
Firefox is offline   Reply With Quote
Old 04-18-2011, 12:04 AM   #1084
Can you do your best to help me?
Have you known these:[url="http://www.2joygame.com/"]Cheapest WOW Gold[/url],[url="http://www.zyy.com/gold/Rift-Planes-of-Telara-US-Platinum.html"]Rift Platinum[/url],
SundayForever is offline   Reply With Quote
Old 04-18-2011, 03:28 AM   #1085
csrcxd's Avatar
Originally Posted by Firefox View Post
Yep !
Then, may i know which city? I would be totally willing to pay for your work on my chip ;D
csrcxd is offline   Reply With Quote
Old 04-18-2011, 03:54 AM   #1086
QuangVuong's Avatar
How to is up! First post this page.
Old 04-18-2011, 04:38 AM   #1087
This unit is back in stock at Hobby King! $28.99.
But it is at Singapore warehouse, not USA warehouse
H0bby Partz told me they would have it in their USA warehouse within 2 weeks.
RobsPics.com - RC Action and Sports Pics (w/ 2011 ROAR Carpet Nationals Pics)
RCBabes.com - Hotties, Cuties, and Product Photography
"A girls legs are her best friends, but the best of friends must part." Redd Foxx
Robs Pics is offline   Reply With Quote
Old 04-18-2011, 04:39 AM   #1088
Thank you, I will try that myself and probably offer this service to USA people
Old 04-18-2011, 12:31 PM   #1089
I have successfully programmed mine by using the file that was posted a while back that just showed the different lines that needed changed. I don't understand what I changed. I don't have the 200 epoint though. Mine already has an issue when epoint is at 120 and I turn all the way to the right the throttle goes full open. Maybe that will go away with a file someone else could possible provide me.
If you have a tried and true file could you please email me a copy. I use hotmail.com and my username is fixitrod. it would be very helpful.
Also, if there are any tricks to reading these files or instructions somewhere else I'd like to see how to manipulate them as well and understand what I'm changing.
fixitrod is offline   Reply With Quote
Old 04-18-2011, 12:36 PM   #1090
Default Fixed my Communication Error from STM8 Programmer
when connecting my board I had to use 3 of 4 wires or my transmitter would keep shutting off as soon as I hit transfer. I had to remove the wire that is closest to the three buttons on the transmitter. When looking at the transmitter there are 4 holes. It's the one furthest to the right if you're holding it like you are driving. After disconnecting that, breaking the board, and turning on the controller like normal it all worked.
Old 04-18-2011, 12:46 PM   #1091
Thumbs up
QuangVuong,
Good job on figuring this out. Can you send me the custom firmware with the Trim, End Point , and EXP fix/mod? PM me for email. Thank you. Or if you could put it up on MediaFire or whatever online Free File Hosting...that would be even better
Mataleao9380 is offline   Reply With Quote
Old 04-18-2011, 01:21 PM   #1092
Hi everyone,
New on the forum. Ive decided to register because Im amazed with all that you guys have done with this transmitter.
Special thanks to PSX and QuangVuong for the how to, its really good!
Id like to mod my firmware as you did specially to get working expo, higher trim values and longer backlight time but is there any chance to get the file with the new firmware modified?
If anyone could do that Id go for the STM8 board to do it myself.
davidpcastro is offline   Reply With Quote
Old 04-18-2011, 01:45 PM   #1093
reptile's Avatar
Trader Rating: 138 (100%+)
"I will offer a service which I will reprogram the radio to whatever settings you want.
Theses were my mods: fixed expo, trims set to +-99, 9.6v low voltage, 1 min backlight and 200% max EPA. It will cost $5 per radio."
Hi grat that you can work with the GTB3
I would sugest a lower EPA # no use for 200% may cause damage to servos from people who do not know what they are doing... 150% is a better typical setting or 120%
Also the trims 99 is over kill maybe 50 + - is a respectfull setting.
I just trashed my GTB3 and set up a KO mars R to work with all my boats and RC cars on the GTB 2.4 modual I was sick of all the fiddling around with the GTB3.
reptile is offline   Reply With Quote
Old 04-18-2011, 04:57 PM   #1094
Great How To!
HobbyPartz has them and the rx back on the website as of today. Good Luck!!
My last order was cancelled, out-of-stock in 24 hours.
Losi xxxS G+ Ti, Sidewinder 5700, Gens Ace, FS-GT3B
Losi xxx4 G+ Stock, shared motor ecu radio
*Unused Vintage TC body? I may be interested in buying*
mini702 is offline   Reply With Quote
Old 04-18-2011, 05:11 PM   #1095
QuangVuong's Avatar
PM'd.
Yeah, I had to break my board for it to work.
Originally Posted by Mataleao9380 View Post
QuangVuong,
PM'd. Ill send to your email cause its easier. And welcome to RCtech.
Originally Posted by davidpcastro View Post
Hi everyone,
No worries, but you also forgot Firefox. PM'd
Well I guess the 200% EPA is way to much but it gives adjustability. I drift so I want max servo travel. And I know what Im doing. Yeah, Ill leave it stock 120% for others unless they want the 200%.
+-99 trim is just more adjustable. +-50 isnt much of a jump from the +-30 which moved the servo about 1 tooth.
If anyone else wants the file, just PM me with your email and what setttings you want. Thanks
Tags
page 100 for all info
