Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 10-16-2010, 05:58 PM   #1441
hacker's Avatar
Trader Rating: 141 (100%+)
are the xerun brushless motors ROAR legal?
what other motors can work with the hobbywings thermal protection system?
hacker is offline   Reply With Quote
Old 10-16-2010, 08:31 PM   #1442
begrie's Avatar
Thank you so much for all the guidelines!
My bad, i will try tekin redline 10.5 for 528stock SW.
Anyway need guide for today actions.
How bout if im using ezrun 5.5T, can i use 528mod SW? Is it i still can add supercharge in it? Or supercharge or turbo only for sensored motor?
Thank you!
Dragsterz Riena Rc Kelantan
sANwa / gQ / SpeedMind / Team AssociAteD / YoKoMo /
SAKurA ZeRo / HoBbyWing / Tekin / PacTra / TamiYa / ProToForm / HSp
begrie is offline   Reply With Quote
Old 10-16-2010, 10:54 PM   #1443
TeamWTF's Avatar
Thank you!
The dynamic timing function only works with sensored motors...
Ezrun is sensorless. 5.5t should be fast enough anyway...
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 10-17-2010, 04:03 AM   #1444
HI, I am new to hobbywing, I have an xerun 60A speedo, if I can the interface box will I be able to use the downloadable settings? or is this just for the 120A
cheers..
michael.branth is offline   Reply With Quote
Old 10-17-2010, 05:28 AM   #1445
cheers..
It works with both the 60A and 120A Xerun Speed Controllers.
Oggie is offline   Reply With Quote
Old 10-17-2010, 03:51 PM   #1446
COBRARACING's Avatar
They are being tested as we speak for roar approval .motors that can be used Lrp ,Novak ,speed passion
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-17-2010, 09:04 PM   #1447
BRC
BRC's Avatar
Hi,
I'm using a V2 120A ESC.
I just bought an X12 Stock Spec 10.5T.
To run the turbo functions...
What settings would you guys recommend? (Esp those already using this motor with the ESC)
Regards,
BRC
EP Touring: Xray T4'14 / DualSky 870 combo
GP Offroad: Agama A8 / RB WS7
EP Drift: Xray T2'007 / Mamba Max
Mini: M05 Xevo conversion
Mini Z: Atomic BZ
BRC is offline   Reply With Quote
Old 10-18-2010, 12:50 AM   #1448
Holmenkollen's Avatar
Originally Posted by COBRARACING View Post
I dont know much about the tekin motors but i know from my background in electronics and electrical that the tekins might be wired in a delta configuration giving them more top rpm with the same turns as any other motor .They may also be using different type of wire as well .
some info so you understand is below.
The delta configuration connects the three windings to each other (series circuits) in a triangle-like circuit, and power is applied at each of the connections. The wye ("Y"-shaped) configuration, sometimes called a star winding, connects all of the windings to a central point (parallel circuits) and power is applied to the remaining end of each winding.
A motor with windings in delta configuration gives low torque at low rpm, but can give higher top rpm (example tekin motors). Wye configuration gives high torque at low rpm, but not as high top rpm.
Do these type of different configurations affect the ESC? Work harder on delta?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-18-2010, 11:23 AM   #1449
begrie's Avatar
Hi, need help here....
Track straight 100m... ( Sprint test )
Xerun 120A v2.1.
Battery orca 50c.
4.5T tekin redline 13mm rotor.
Need to run faster.. Which SW should i use?
and what FDR is the best to outbeat tekin rs pro.
Is it ok to use 4.9FDR?
Please help me.....
Old 10-18-2010, 04:42 PM   #1450
M7H
M7H's Avatar
@Cherry2blost.
Thanks mate!
Received everything today, put it in the car, uploaded the 518stock, now it's up to the track Wednesday evening...
Do you recommend to put on the coolingfins (not fan) with running 13.5T with 1S lipo?
Serpent
Last edited by M7H; 10-19-2010 at 03:59 PM. Reason: changed 512stock into 518stock
M7H is offline   Reply With Quote
Old 10-18-2010, 08:13 PM   #1451
BRC
BRC's Avatar
Hi,
I need help.
FDR for 10.5T?
Regards,
BRC
Mini Z: Atomic BZ
Old 10-18-2010, 09:02 PM   #1452
Originally Posted by BRC View Post
Hi,
I need help.
FDR for 10.5T?
Regards,
BRC
BRC
i dont use this motor but i have a starting point for you ok.
if you use 10.5 ,you can try this setting:
9=6
12=7 or 8
13=4
14=5
15=4
FDR : 6.4
let me know hwo you go
regards Angelo
Old 10-18-2010, 09:04 PM   #1453
some yes as the delta will give you more rpm on top so for example voltage and the star config will give you more current basically more bottom end torque .more current more heat more rpm more heat as well
Old 10-18-2010, 11:28 PM   #1454
Born2Run's Avatar
Originally Posted by M7H View Post
@Cherry2blost.
Thanks mate!
Received everything today, put it in the car, uploaded the 512stock, now it's up to the track Wednesday evening...
512stock? Are you sure about this?
Whatever
Born2Run is offline   Reply With Quote
Old 10-19-2010, 02:27 AM   #1455
M7H
M7H's Avatar
No, certainly not from work, where I am now...
But it's probably a typo, and should be 518stock...
Serpent
